I have something on my hull that is peeling off. At first I thought it was Vertglas or Polyglass but I have tried everything to get it off (Ammonia, vinegar, paint remover, floor stripper, acetone,Polyprep) and nothing will touch it. Does anyone have any idea as to what this stuff might be?? It is very thin and looks like a layer of acrylic or polyurethane.
If I have to resort to wet sanding it off, what grit paper do ou recommend?
Clear? Amber? White? Sounds suspiciously like some DPO painted your hull (maybe Awlgrip or Imron)... This is generally what happens. Hopefully, the color contrasts at least slightly with the underlying gelcoat. If so, a small orbital sander with the finest possible sandpaper (do some tests) should get it off and leave the gelcoat. Hand sand around any corners and edges. Wear a mask and goggles. I wish you the best...
I would start out with 1600 or maybe 2000 grit sandpaper. Then progressively move to 2400 and maybe even 3000 to finish. The higher the number the finer the grit. You will be amazed how shiny a hull will look after using 2500 - 3000 grit.
You'll have to experiment with the grit--it depends on the material you're taking off, the pressure you want to apply, the sander you're using, etc. You really don't want to cut through the gelcoat. The original boat had about 1/16th inch of gelcoat (on average), so you should be able to cut the paint off without going through, although this raises the question of why the hull was painted. 3000 grit and then some 3M fiberglass restorer (which has a very mild compound) should finish it up, unless you prefer Poly Glow or Vertglas.
Thanks for the thoughts. I have tried to power wash it off and a good deal of it came off. However, where it has adhered well it will not come off. The stuff is clear like Vertglas but when it comes off it is very thin and looks whitish. The fellow that put the stuff on is now dead so I can't ask him what it is. It might be worth noting that the underlying gel coat is in very good condition so I think it was put on as a permanent shine.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Frank Hopper</i> <br />Vertglass and PolyGlow have specific strippers, I suppose I would buy some and try it. Vertglass is at lovettmarine.com <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
I actually called POlyglow and they told me that their stripper would also remove Vertglas...however, it did not work. So, I guess I am back to sanding.
Yup--Poly Prep is mean stuff. I think you have some sort of urethane, which generally isn't phased by paint strippers, much less polymer finish strippers. The whitishness might be some gelcoat chaulk. How about some heat (not so much as to soften the gelcoat) along with dull scraper? Just grasping.....
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">The fellow that put the stuff on is now dead so I can't ask him what it is.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
