 Capri 25 Specific Forum
 Mast Step
patchaff
Initially Posted - 12/09/2006 :  08:18:01  Show Profile
I am searching for a mast step for my 1981 Capri 25. I spoke to Kent at the factory and he indicated he doesn't have the cast in stock or even the name of the manufacturer. The step I have has severe corrosion and the sheaves need replacing but the *&%@^*%! retaining pins are corroded in place. Lubricants and punch pin hammering have been to no avail.
Does anyone have a source for the step, non OEM step replacement, name of the mast manufacturer or an idea how to restore the step?
existentialsailor
Response Posted - 12/09/2006 :  09:44:21  Show Profile
Chris has the drawing for the mast on his site, but there isn't anything for the step casting itself. Maybe this will help you track it down.
[url="http://capri25.com/DRAWINGS/Cp%2025%20Mast%20Section%20(Large).JPG"]mast drawing[/url]
If you're a member of the yahoo capri group, you should post there as well, if you're not, let me know and I'll post for you.
patchaff
Response Posted - 12/10/2006 :  06:06:33  Show Profile
Thanks Rick, unfortunately I can't open your attachment. Is it a PDF file?
I didn't know there was a YAHOO Capri group so any help in posting would be greatly appreciated. I would think this may be an issue for others given the age of our boats.
Thanks for the info and support.
existentialsailor
Response Posted - 12/10/2006 :  06:18:30  Show Profile
Yes, that is a PDF file.
The Yahoo group is [url="http://groups.yahoo.com/group/Capri25/"]HERE[/url]
You have to join to post, if you don't want to join, I'll post on your behalf.
patchaff
Response Posted - 12/11/2006 :  06:13:53  Show Profile
Thanks Rick, I applied to Yahoo for membership. Unfortunately, I can't seem to open your MAST file. It says the file is no longer available.
Thanks for all the help.
On an unrelated note, I have figured out how to replace the bulkhead if anyone needs the process, let me know.
Regards,
existentialsailor
Response Posted - 12/11/2006 :  08:39:58  Show Profile
Her's the link, just tried it and it worked:
Try a cut and paste, or just go to Chris's site and scroll down and click the mast section link on the left.
As to the bulkhead, there has been a lot of discussion about that just recently, you might want to write up the process and if you have pictures that's even better. Chris may want to use it for a technical article in the Mainsheet as he's the technical editor for the Capri 25.
Ericson33
Response Posted - 12/12/2006 :  01:36:11  Show Profile  Visit Ericson33's Homepage
I am always looking for stuff to add to the site. Post it on the forum and I will put it in the mainsheet so everyone can take a look. Did you try Catalina Direct? I also thought I saw one on Ebay 4 months ago, I will look again and see if its still there. Another idea is to unbolt the mast step and take it to a machine shop and see if they can drill out the pins and replace them. Just a thought.
saribella
Response Posted - 12/13/2006 :  09:44:55  Show Profile
Kenyon Spars? http://www.rigrite.com/A-Main/spar_M.html
patchaff
Response Posted - 12/13/2006 :  19:12:56  Show Profile
Great, thanks. Is anyone using the Keynon step with 4 sheaves? If so, how did you handle the 5th halyard?
Thaks so much.
Regards,
Pat
Ericson33
Response Posted - 12/14/2006 :  13:29:38  Show Profile  Visit Ericson33's Homepage
One main, One Jib, One Genoa, One topping Lift for pole all exit at the base, and the spinnaker halyard, just drill a cut-out on the starboard side of the mast and add a cam cleat so you can get the spinnaker up fast.
patchaff
Response Posted - 12/15/2006 :  13:20:49  Show Profile
Thanks for all the help. By any chance would anyone have a picture of their mast/sheave/halyard setup?
Thanks so much. Now that I have the bulkhead ready to go back into the boat, I'm ready to finish the mast step.
Ericson33
Response Posted - 12/15/2006 :  18:04:13  Show Profile  Visit Ericson33's Homepage
I don't have a photo but will tell you how mine is setup. From Port to Starboard.
Outside port,
Jib Halyard - Blue Spec- 5/16
Boom Vang- Solid Red- 5/16
Cunningham- Solid White- 1/4
Reefing Lines - Solid Blue - 1/8
On mast Starboard Side - Spinnaker Halyard - Solid Black 5/16
Inside Starboard
Genoa Halyard - Green Flek 5/16
Main Halyard - Solid Blue 5/16
Toping Lift - Solid Red 5/16
Downhaul - Solid Green 5/16
