 Zink
budd
Initially Posted - 08/21/2006 :  22:32:57  Show Profile
Is there a recommended place to install a Zink on the keel, I've a 80 swing keel with no zink that i can see.
Bud
Response Posted - 08/22/2006 :  09:47:14  Show Profile  Visit Leon Sisson's Homepage
Bud,
On my 1979 swing keel, I installed zincs near the attachment points to the boat. I have a pair of pancake zincs near the cable attachment held on by bolts into holes tapped into the cast iron. My C-25 is a bit non-standard at the pivot, but something similar should work. I have four zincs bolted to the fiberglass with 10ga wiring in the bilge connecting them to the pivot hardware. Or, you could use another pair of pancake zincs on the cast iron near the pivot - but keep in mind which areas of the keel will be going in and out of the trunk when the keel is lowered and raised.
