I have a 1985/86 Catalina 25 with a non-functioning bow light. I tried all the obvious things and couldn't get the light functioning. Is there a possible fix that is easier than running new wire from the fixture back to the fuse box. All the other lights on the boat are working OK. The bow light bulb and related wiring/fuse behind the switch panel all seem to be OK. Thanks.
I would first get an auto fuse tester and see if you are getting power to the bow light. If so, it might be the original sccks that have gone bad. Eighter way, the best thing to do is to buy a red/green bowlight that mounts high up on your bow pulpit. You can see them much better in heavy seas. Cheers.
I recently fixed my non-functioning bow lights. Using a simple circuit tester I discovered that I had workable circuit. I replaced both sides for about $3 and now have functional lights. You can get just 'contacts and wires' that fit in the existing sockets. I tried to find replacement sockets but found the contacts at an auto parts store. It was the cheapest most time effective solution. I can post pictures next week if that would help.
There's a disclaimer posted along with the lights on one of the sites that sells them... they aren't legal for boats over 20' (I think that's the length anyway)
Using a simple electrical continuity tester (one with a probe and an alligator clip), I found that the problem with my bow lights was in the socket. I went to a marine store and an auto parts store and was unable to match up the socket. So I replaced the guts of the socket and now my lights are working. This is a picture of the guts (contacts) that I cut out and replaced. Cost was about $3 for two. I probably could have just cleaned up the contacts, but for the price, replacement seemed best. So far, the best two electrical tools on board my C25 are the continuity tester and my volt meter. I hope this helps.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ClamBeach</i> <br />There's a disclaimer posted along with the lights on one of the sites that sells them... they aren't legal for boats over 20' (I think that's the length anyway) <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
I believe that disclaimer only applies to the incandescent (krypton bulb) lights. There are Innovative Lighting portable LED lights that aren't marked for "small boat". Actually come to think of it, maybe it's 20 meters instead of 20'?
Thanks for all the great reponses. I will try to get the bow light working again this weekend. I would like to try sailing in the evening -- seems like a great time to be on the water. Larry
