 Capri 25 Specific Forum
 Spin Sheets
SailCO26
Initially Posted - 06/01/2006 :  16:39:47  Show Profile  Visit SailCO26's Homepage
Woo HOOO! I finally got under sail, and y'all were right - whatta ride!! Makes the ol' CP26 look like a truck.
As luck would have it, it was even Race night. So we opted in and had a blast (myself and 1 crew). We ran gen/main only as we've yet to figure out the kite (see below) and there was a nice cell moving in. DAM, but this boat can accelerate! Responsive, too - I had a bad tendency to over-steer, will be working on that one.
Sooo, in looking thru the line selection I'm not sure what's what. Assuming I need to start fresh, what do you all recommend for spin sheets (length, dia, type)? What about pole downhaul? And where do you store the pole upwind?
Thanks in advance, this forum has been a HUGE help!
Jim
#183 - Team Short Bus
CP25 #183 - Team Short Bus
Capri25 Measurer 2007(ish)-2010
Douse: [dous] v, a: to lower or take in suddenly; b: to stow quickly; c: ease, with vigor
Regret is the bastard child of desire and inaction.
Ericson33
Response Posted - 06/01/2006 :  20:58:03  Show Profile  Visit Ericson33's Homepage
I have two different sheets for the spinnaker, One is 5/16 and the other set is 3/8 for heavy wind. The lenth is right at 60'-0" on both sets. The downhaul is 5/16. As for storage of the pole upwind, we have another spinnaker pole car set at the bottom of the track, this also has a snap shackle attached to it to hold the topping lift. We just snap the pole on the ring when we store the pole, and snap the topping lift in. I have found that this keeps the downhaul and topping lift from twisting up, and allows for the topping lift to remain attached to the pole. All of the sheets are a double braid Sampson. I think I bought ours from Milwalkee Rigging.
Lets see some photos
Turtonjs
Response Posted - 06/19/2006 :  15:33:21  Show Profile
I snap my pole on the starboard shroads so it's easy for the foredeck to access from the rail when approaching a weather mark on starboard tack. This way, they can unsnap the pole, pull it back, feed the guy through the end and then push it forward, all from the rail.
Don't get spin sheets that are too short, mine are about 18" to short and I'll tell you, IT MAKES ME INSANE.
Every Capri 25 I've seen has typically been oversteered. These boats are extremely sensitive to the touch and even a bit squirrely due to the size of the rudders, as well as the placement of the rudder. My experience has been with J24's and the adjustment in rudder placement is a huge change.
Happy sailing!
-Josh
