 Capri 25 Specific Forum
 Battery Spill HELP!
Mark Maxwell
Initially Posted - 05/28/2006 :  21:07:18  Show Profile
It seems that my battery spent the winter on it's side. All of the acid spilled out and has settled in the bilge. I have a fin keel so the lowest point is the area that the keel is bolted to the hull. I've cleaned the entire bilge with sodium hydroxide to nutralize the acid. any idea on the affect this will have on the fiberglass? I've noticed some discoloration to the keel just about where the 'smile' usually is located. I sprayed it with the caustic and got a small reaction. So I'm sure that some of the acid followed the keel bolt to the keel...not lead it's iron. What other concerns should I have....I'm sick about this.
Mark-
'Impulse...’
1978 C25 #533 SR/DIN/FIN ~_/)~
Bakersfield, CA.
