 New Bow Cleats
Rich G
Initially Posted - 04/25/2006 :  19:03:28  Show Profile
I replaced the stock bow cleats today with larger cleats. Unfortunately, I was unable to reuse either hole from the original cleats. I just filled them in with epoxy. Is there anything else I need to do to keep water from getting into the core from the old holes?
Rich
Cerberus
Hull #4695
1984 SR/FK No Pop-Top
Response Posted - 04/25/2006 :  19:40:56  Show Profile  Visit Frank Hopper's Homepage
I replaced mine.
Tom Potter
Response Posted - 04/25/2006 :  19:46:00  Show Profile
Frank, those are cool!
Admin
Forum Admin
Response Posted - 04/25/2006 :  20:58:17  Show Profile  Visit Admin's Homepage
If you filled them with epoxy you will be fine. Aesthetically it is going to have a mark (if not covered) but as far as water coming in through the holes you should be sealed up.
dw
Response Posted - 04/25/2006 :  21:13:54  Show Profile  Visit britinusa's Homepage
are they made of Kryptonite?
stampeder
Response Posted - 04/25/2006 :  22:20:42  Show Profile
Great idea Frank, I was so inspired that I ran out to get a glow in the dark toilet seat for my porta-potti.
Rich G
Response Posted - 04/25/2006 :  22:43:49  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Admin</i>
<br />If you filled them with epoxy you will be fine. Aesthetically it is going to have a mark (if not covered) but as far as water coming in through the holes you should be sealed up.
dw
That's what I thought. What would be the best way to cover the hole, which is under the gap between the posts of the new cleat? Can I cover it with gel coat? Or will I have to glass it over first?
Response Posted - 04/25/2006 :  23:06:04  Show Profile  Visit Leon Sisson's Homepage
Rich G<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">What would be the best way to cover the hole,...Can I cover it with gel coat?<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">If your epoxy plug is well bonded, gelcoat should be easy. I'd try to create a very shallow rough depression at the patch (around 0.025" to 0.050" or so deep, maybe with a tiny sanding drum?), and refill that flush with gelcoat. Or for a 1/4" hole under a cleat, I think I might be satified with the a strong epoxy patch. For future reference, one can make a fairly 'white' epoxy filler from WEST resin, WEST white pigment, and white (glass) microballoons. White MarineTex(?) epoxy putty is good stuff too, if the consistancy meets your needs.
tmhansen
Response Posted - 04/26/2006 :  02:23:36  Show Profile  Visit tmhansen's Homepage
Frank if I put those on my own boat I would probably scare the hell out of myself some night! Where did you find those?!
Response Posted - 04/26/2006 :  10:21:52  Show Profile  Visit Frank Hopper's Homepage
Gander Mountain. $11.
