 Edson Wheel Brake
tomara
Initially Posted - 03/28/2006 :  09:40:40  Show Profile
Is it beneficial for me to install the Edson Wheel Brake to my pedastal? I plan to sail single-handed much of the time.
Thanks.
Tommy
'Reverie'
2002 C250WK #613
reuben
Response Posted - 03/28/2006 :  12:46:25  Show Profile
I've found it helpful, not only for shorthanded sailing but for easing the load on arms & shoulders. It's simple to install (remember to stuff a rag just below assembly so as to catch any parts you may drop down the pedestal) and a worthy upgrade, though costwise Edson will soak you badly.
zebra50
Response Posted - 03/28/2006 :  13:31:12  Show Profile
I had one installed when the steering system was installed and use it all the time. It is handy when going forward, holding the rudder off to the side when at anchor and swimming, and most importantly when eating while sailing.
Response Posted - 03/28/2006 :  20:19:31  Show Profile  Visit britinusa's Homepage
I just wish the break didn't squeak when it's used to add a bit of stiffness to the steering.
Al
Response Posted - 03/28/2006 :  21:31:21  Show Profile
Do you plan on getting an autopilot? If so, it will work as a brake.
SEAN
Response Posted - 03/29/2006 :  07:31:56  Show Profile
Hey Paul ,
If it is squeaking , try spraying it with
car brake cleaner . stuff a rag in there so it doesnt drip inthe bearth . And try not to wash the grease off the chain . If it still sqeaks ,
take it apart and scuff the pads with sand paper and spray again . or you might find you need a new pad.
Works on a car when they glaze over from use.
Edited by - SEAN on 03/29/2006 07:36:49
frogger
Response Posted - 03/29/2006 :  09:37:43  Show Profile
I think of it as a must have. As above I also use it when just anchored or floating to keep rudder from moving side-to-side. When sailing it cuts down on overcompensating rudder movement.
tomara
Response Posted - 03/29/2006 :  10:34:24  Show Profile
All:
Good advice...Thanks.
I'm going to add the brake...carefully.
Autopilot is not in my plans.
