After reading the threads on the C25 forum about 4 spring and 2 spring brackets for their outboards, it got me thinking...
Would it be worth it to install a bracket on a 250?
Pros of using a bracket <ul> <li>Prop is further from rudder. </li> <li>Tiller is not contstrained by the outboard well</li> <li>Easier to raise the engine? </li> <li>More room on stbd side of fuel locker. </li> </ul> Cons <ul> <li>Weight further aft </li> <li>Cost </li> </ul>
Has anyone got a bracket on their C250? reviews????
I have the factory bracket installed on my boat (WK, 817). Since I have not experienced the boat without the bracket I can not comment much on not having one however:
I find that I have no problem raising the engine or rotating in either direction.
I do seem to have a fairly easy time backing the boat once I have learned that you must use the rudder in conjunction with the motor.
I have not installed a 'soft link' (yet) but seem to be able to back ok using the wheel.
I have a 2004 Mercury 8 HP 4 stroke (long shaft) with the shift in the throttle (boy that took a while to get used to!)
The engine is certainly out of the way with the bracket installed. It does not project into cockpit.
