 Teak Lumber
jfesi
Initially Posted - 03/22/2006 :  09:18:14  Show Profile
Does anyone have any suggestions for where to purchase teak plywood or vernier, and also the white laminated wood like what is already in the 250 interior? Any info would be greatly appriciated.
Joe
Joe F
Veliero
C250WK
#713
JJM
Response Posted - 03/22/2006 :  18:27:49  Show Profile
Marine grade teak plywood:
http://www.noahsmarine.com/United_States/Plywoods-us/body_plywoods-us.html
Check them out, see what you think.
Tom Potter
Response Posted - 03/22/2006 :  19:24:08  Show Profile
And if your needing any [url="http://search.ebay.com/teak-lumber_W0QQfkrZ1QQfromZR8"]Teak Lumber[/url] try my favorite shopping spot.
Response Posted - 03/22/2006 :  19:52:47  Show Profile  Visit Frank Hopper's Homepage
http://www.jamestowndistributors.com/to.jsp?eclDrill=2536&TYPE=MORE
http://www.buckwoodcraft.com/
I have bought from both, Buck are really nice people.
Jamestown is a great catalog
stewendkos
Response Posted - 03/22/2006 :  21:36:19  Show Profile
Joe,
If you want to do it yourself,it can be done.
White laminated wood= Pressed wood with white formica with contact cement.Pricey so I buy remnants at the cabinet shop.Don't laminate to anything except particle board or pressed wood because plywood won'nt give you a smooth surface; then use teak around the edges.Milamine won't hold up;however,you can use the opposite side of it(partile board) then you have a nice white look underneath as well.Full 4x8 sheets can be purchased at Home Depot.It's a tricky process but do-able.You'll need a router.You cut the formica 2-3 inches larger than the wood,contact cement it on(apply cement to both surfaces,let it setup 10-15 minutes then put it on rolling it firmly.Then go for it with the router.
Steve
e-mail me if you need more info
Edited by - stewendkos on 03/22/2006 21:41:32
jfesi
Response Posted - 03/23/2006 :  09:19:18  Show Profile
Thanks everyone for your suggestions. I think that I've got a good handle on it. I have modified the galley so that the coutertop lifts up to allow direct access to the cooler and I just need to close it up.
Thanks again, Joe
Tom Potter
Response Posted - 03/23/2006 :  09:52:57  Show Profile
Post some pictures when your done. That sounds like a interesting mod.
