 Rule Bilge Pump - Installation
Tom Potter
Initially Posted - 10/08/2005 :  20:11:29  Show Profile
Spent the day installing a Rule 1100gpm Automatic Bilge Pump.
Mounted the three way switch between the LP switch and electrical panel. Ran a wire from the battery to the switch, the switch has a built in fuse, but I also installed a fuse inline near the battery.
Ran the discharge hose along side the existing hand pump hose, had to drill a couple holes in the wet locker to run the hose and I put the through hull next to the existing hand pump through hull.
1997 250 TR WK (sold)
1984 O'Day 28 (sold)
1979 SISU 22
Bath, NC.
