 OPENING PORT REPLACEMENT
RSHOOTER
Initially Posted - 09/04/2005 :  18:01:52  Show Profile
My 1999 C250 Wing Keel has a Beckson Opening Port in the Head area. The part that opens has one of the hinges broken. Does anyone know where I can get a replacement for just that piece? I definitely don't want to remount the whole thing. Thanks.
Bubba
Response Posted - 09/04/2005 :  21:18:13  Show Profile
I had broken hinges when I bought my 1997 C250wk. Problem was the broken part was on the port frame, not the piece that opens, so I had to replace the whole thing. Getting past the 5200 they glued it in with was a pain. After that, it went fairly easily. I'll see if I can find the Beckson part number for you.
RSHOOTER
Response Posted - 09/05/2005 :  09:56:18  Show Profile
Thanks Bubba that would help a great deal. As far as I can tell the broken hinge is on the lens side. I haven't torn it apart yet. How did you defeat the 5200?
Response Posted - 09/05/2005 :  15:16:46  Show Profile  Visit Arlyn Stewart's Homepage
http://www.stewartfam.net/arlyn/headport.html
RSHOOTER
Response Posted - 09/05/2005 :  16:07:22  Show Profile
Arlyn, good info as usual. Do you have the Beckson Model #...? I'm still hoping to only replace the Lens piece but may have to buy the whole thing. Did you use 5200 to reseat your new Port or somethng else? Thanks.
Bubba
Response Posted - 09/05/2005 :  18:51:14  Show Profile
I used a clear marine silicone sealant instead of 5200 on the replacement. My reverse logic was: If I make subsequent replacement easier, I'll never need to.
I think the paper that came with my replacement port is somewhere on the boat, which I won't get back to until the weekend. This Beckson website might be more useful to you anyway:
http://www.beckson.com/replace.html
And yes, you can just order the lens.
Response Posted - 09/06/2005 :  07:02:46  Show Profile  Visit Arlyn Stewart's Homepage
I have the Beckson and it simply depends on which part failed. I don't recall what I used to bed the replaced port with... too many years ago.
RSHOOTER
Response Posted - 09/06/2005 :  07:08:01  Show Profile
Thanks Bubba, if you run across the paper with the Model Number please let me know. I have sent an E-Mail to Beckson but haven't gotten a reply.
RSHOOTER
Response Posted - 09/18/2005 :  18:25:39  Show Profile
Well, Bubba it's a Beckson Model 410..I got the Lens only but the last two Ears on the Frame broke off when I was installing. They seemed pretty brittle. Now, I have to do the whole body which is not much fun. Beckson provides great service.!
Bubba
Response Posted - 09/19/2005 :  21:04:18  Show Profile
I went through all my boat-related papers yesterday but couldn't find anything for the port I replaced. I measured it though, and was going to tell you it was a 410, but I see you already know that. When I replaced the port, I struggled through the sealant with a cheap steak knife (we get 'em when we buy a box of deli meats). The knife has a thin flexible blade. I also used a razor blade scraper. I've read where others have used a thin wire (guitar string?) to cut through the sealant. Might be worth a try...
Good luck with the replacement!
