 cover for jib on rf
sdaly66
Initially Posted - 09/09/2003 :  11:42:37  Show Profile
Anyone know a good source for a sunbrella cover for a jib on a roller furler?
This site is a GREAT resource full of VERY helpful folks.
250 WB 1996 Hull #205
Thank you all.
wmkoines
Response Posted - 09/09/2003 :  11:48:42  Show Profile
Try Catalina Direct they have.
www.catalinadirect.com
deastburn
Response Posted - 09/09/2003 :  12:13:14  Show Profile
Normally rf jobs are made with "sacrificial" cloth, usually sunbrella or similar. Were you planning to sew this on (not an easy task) or am I missing the point?
Dave on "Wood Duck" (#2616)
sdaly66
Response Posted - 09/09/2003 :  12:16:16  Show Profile
Dave,
Mine does not. I think I'd rather go with a cover since I believe this sail has a few more years left in it.
Thank you all.
Douglas
Response Posted - 09/09/2003 :  13:18:49  Show Profile  Visit Douglas's Homepage
DO NOT I repeat DO NOT use the iron on type of leading edge RF cover. After aplication and a few rolls the rinkle bag and generaly ruin the sail shape.
Doug&Ruth
Triska (Alberg 29)
Tacoma Wa.
Sea Trac
Vanuatu
Response Posted - 09/09/2003 :  13:23:41  Show Profile
Shawn,
Were you referring to 1) a cover that is sewn on to the foot and leech or 2) a slip on cover that you run up with a spare halyard?
#1 can be supplied by your local sail loft. #2 can also be supplied by your local sail loft, Catalina Direct, the Chandlery at catalinaowners.com, etc., etc.
J.B. Manley
<img src="http://im1.shutterfly.com/procserv/47b3d609b3127cce8d2e212441c60000002010" border=0>
Antares '85 FK/SR #4849
36°29'58" -94°59'59"
sdaly66
Response Posted - 09/09/2003 :  13:36:05  Show Profile
Thanks all. I've got some good sources to search now.
Thank you all.
osmepneo
Response Posted - 09/09/2003 :  15:54:37  Show Profile
If you are planning the sacrificial edge material,I would send sail to a sail mfger and have them do it.
If you are planning a sock which you raise with a sapare halyard, the material, sunbrella can be gotten, at here at an awning manufacturer. They will make, or sell the material for you to make.
Don Peet
c25, 1665, osmepneo, sr/wk
The Great Sacandaga Lake, NY
