 Gate Valve Question
Blowboat
Initially Posted - 07/09/2023 :  14:03:45  Show Profile
I need to remove the marine head from my 1983 C-25 while it is still in the water. My boat still has an old gate valve (think that's what it is called) rather than a seacock.
Can anyone tell me which way way to turn the valve to close it? (I'd rather know this now before removing the hose!) :)
Thanks in advance!!!
Joseph Washburn (Southport, NC)
1983 C-25 FK/TR
"Disciple Ship"
#4090
Response Posted - 07/09/2023 :  14:32:19  Show Profile
Clockwise or Righty tighty. If this is the famous gate valve that's in a fiberglass volcano then please be very cautious when applying any pressure to it. The have been known to just pull out of the volcano leaving you with a hole in the boat. Good luck!
Blowboat
Response Posted - 07/09/2023 :  17:16:14  Show Profile
Thanks! And I will. Replacing these things is high on my list!
1983 C-25 FK/TR
"Disciple Ship"
#4090
Response Posted - 07/10/2023 :  06:06:38  Show Profile
Have a wooden or rubber cone available. Those bronze pipes have crumbled in people's hands (from what I've read here--I had ball-valve seacocks on proper thru-hulls).
Edited by - Stinkpotter on 07/10/2023 06:08:15
Blowboat
Response Posted - 07/10/2023 :  13:52:45  Show Profile
That is a great idea! They are always close by...but I'll make sure they are EXTRA close by when I take on this project.
Here is a picture of the valve I am dealing with. Of the three thru hulls on our boat, right or wrong I have always felt this one was the least of my concerns.
https://josephwashburn.smugmug.com/Sailboats/Catalina-25-1/Boat-Parts/Through-Hulls/i-wC669Xm/A
1983 C-25 FK/TR
"Disciple Ship"
#4090
Response Posted - 07/10/2023 :  18:34:18  Show Profile
You never know how corroded the inside of that pipe coming thru the hull might be. Definitely keep those plugs close by. Let us know how it goes.
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Response Posted - 07/11/2023 :  10:26:23  Show Profile  Visit Leon Sisson's Homepage
Re:  "My boat still has an old gate valve..."
Those things give me the creeps.  How old is it by now, 30 years?
Re:  "If this is the famous gate valve that's in a fiberglass volcano ... have been known to just pull out of the volcano leaving you with a hole in the boat."
The photo linked looks like the gate valve may be atop a bronze thru-hull fitting in this case.
Re:  "Can anyone tell me which way to turn the valve to close it?"
I suggest you also verify the valve is closed as early in the procedure as practical.  I don't know how your head is plumbed.  Maybe try flushing some clean water with the valve closed, and see if the pump feels like it's hydraulic locked?  As I recall, one of the failure modes was handle feels more or less normal, even though the gate (a.k.a. guillotine) itself is partly corroded away.
Re:  "Have a wooden or rubber cone available.  Those bronze pipes have crumbled in people's hands..."
I suggest you also think past having a tapered plug handy.  If you need more encouragement to be prepared for trouble, maybe calculate the flow rate through that size pipe that far below the waterline.  Would your boat's automatic bilge pump be able to keep ahead of that?  For how long?   From a potential "Oh crap!" moment, how long will it take you to get your boat out of the water?  By the time it's being lifted, how much more might it weigh from taking on water?
I try to avoid messing around with holes near or below the waterline while the boat is in the water.
— Leon Sisson
Response Posted - 07/11/2023 :  21:12:26  Show Profile
40.
Response Posted - 07/20/2023 :  18:39:04  Show Profile
It is easy to replace a gate valve with a proper one when out of the water. And, after 5-10-20 or so years any valve should be inspected and changed out if the inspection shows any unusual wear.
Peter Bigelow
C-25 TR/FK #2092 Limerick
Rowayton, Ct
