 Some Suggestions for Better Sailing
Initially Posted - 06/23/2023 :  08:52:46  Show Profile
When you're sailing closehauled and there's a wind gust, do you, like most people, pull harder on the tiller? If so, think about what's happening. Whenever you pull on the tiller, you are turning the rudder diagonally across the water's flow. That creates drag. Every time you turn the rudder, you are, in effect, putting on the brakes.
What should you do? In a gust, you should ease pressure on the tiller. Let the boat come up to windward slightly. Why? Because the boat will accelerate slightly, and the boat will take a bite to windward. The hardest ground for a sailboat to gain is ground to windward, so you should take a bite whenever you can.
Think about it this way. In a gust, when you feel increased pressure on the tiller, that's the boat telling you it wants to sail closer to windward. The architecture of the boat and sails are causing it to drive to windward, because that's the way it will sail most efficiently. That's what will make the boat "happy." So, listen to what the boat is telling you and let it do what it wants.
When you understand the meaning of the pressure that you feel in the tiller, you can use that tiller pressure to help you trim the sails efficiently. As the wind increases and the angle of heel increases, you will feel increased tiller pressure. If you just pull harder, you'll "put on the brakes" and you'll lose boat speed and pointing ability. The correct remedy is to ease the traveler (not the mainsheet) to leeward to reduce the tiller pressure. If the gust subsides, pull the traveler up to windward just until you feel the slightest amount of tiller pressure. Many sailors think the boom should always be trimmed to the centerline of the boat when closehauled and some think the mainsail should always be trimmed so that it's uniformly smooth. I've seen some folks even trim the boom to windward of the centerline. The better practice is to trim the boom so that you feel a slight pressure on the tiller. When you do, you'll notice that the mainsail will usually luff slightly at the leading edge. That indicates the most powerful and efficient mainsail trim. It usually produces very light tiller pressure. In very gusty conditions, you'll often find yourself frequently "playing the traveler," i.e. easing the traveler in the gusts and pulling it up in the lulls.
A sailboat rotates on it's axis, which is located at the Center of Lateral Resistance (CLR) in the keel. The jib applies power forward of the CLR, and the mainsail applies power aft of it. Your goal is not to generate the maximum amount of power that you can in both sails at all times. The goal is to balance the forces forward and aft of the CLR. That's what will make your boat sail fastest, point highest, and provide you a light tiller pressure so you won't become arm-weary from fighting the tiller.
Whenever you feel any more than light tiller pressure, don't ignore it. Don't think it's a characteristic of your boat. It can be alleviated by the way you trim the sails, and, in a worst case, by the way the rig is tuned.
Edited by - Steve Milby on 06/23/2023 08:55:24
Response Posted - 06/23/2023 :  17:36:19  Show Profile
Beautifully explained, as usual Steve!
Chief Measurer C25-250 2008
San Antonio, Texas
Response Posted - 06/23/2023 :  17:47:16  Show Profile
Thanks Derek. Nice to hear from you!
keats
Response Posted - 06/24/2023 :  19:09:35  Show Profile
I love this kind of information and can't wait to try it out on my next sail.
So many times I feel I'm well balanced and see that slight luff in the mainsail leading edge. I assumed I had the headsail badly trimmed.
Thanks Steve!
Tim Keating
1985 C-25 TR/FK #4940
Midsummer
Lake Don Pedro, CA
Response Posted - 06/25/2023 :  13:27:53  Show Profile
Steve, not sure what prompted you to write this, but WOW. Great information as we enter the prime of sailing season!
Peter Bigelow
C-25 TR/FK #2092 Limerick
Rowayton, Ct
Response Posted - 06/25/2023 :  15:07:26  Show Profile
I wrote it after Derek asked why there was so little chatter on the forum lately. I hoped it might stir up some interest.
hlprmnky
Response Posted - 06/26/2023 :  09:59:16  Show Profile
I am very much looking forward to applying this information later this week. This is my first season “seriously” getting out on the water - I have a single-digit number of projects to finish up while waiting for the 17-20kt frontal passage to sort itself out here at the southern end of Lake Michigan and then I want to get a shakedown sail in, and take my family out for our first “cruise” to the harbor next door over the 4th.
1986 C25 SR/FK/Trad. “Puffin III” - #5040
Sailing Lake Michigan out of Michigan City, IN
Response Posted - 07/30/2023 :  09:23:29  Show Profile
Steve’s advice, as always, is right on target. It’s always a treat to read about his experience. And it’s so timely since we’ve seen some unusual weather lately with lots of gusty winds.
I like to use the weather forecast and current tables (in tidal waters) for trip planning. For example, a day-sail spanning more than a dozen or so miles, or an overnight, or a three-day trip.
I start with my charts to create a timeline of where I’ll be every two hours during the trip. I’ll use the NWS’s or Windy’s hourly winds forecast and use NOAA’s tidesandcurrents.gov website to do the same for currents. Then, I’ll recursively move onto my next position. My position on the NWS weather map has to follow the timeline and position of where the boat will be at the next 2-hour interval.
For example, if I can normally sail at 4.5kts in a close haul breeze, my next position should be 9 miles away. But if I have a 1kt opposing current then I’ll only make 7 miles. From there, I’ll make the next step, perhaps the wind will have veered by then, so I can only make 4kts, however the current is slack, my next 2-hour position will be 8 miles further.
I’ll continue to do this until I’ve charted my entire course to my destination.
Of course, real world conditions can change things while underway, but it gives you a notion of what you can expect.
Edited by - Voyager on 07/30/2023 10:01:16
