 Bulb Keel
WK 727
Initially Posted - 06/16/2023 :  15:15:08  Show Profile
I modified my keel by cutting off the wings and then adding back a bulb keel. The keel now weighs 1,250 pounds instead of the original weight of 1,050 pounds. I basically added 200 pounds at the lowest point possible and added the appropriate amount of fiberglass layers in the bilge under the keel bolts for the increased stress. More images are in the photo gallery. This was a fun/challenging project to undertake.
Regards, John
Westlawn Institute graduate
Yacht Design and Naval Architecture
04 Catalina 250 WK
Standard rig w/wheel steering
Yanmar 9hp diesel
Edited by - WK 727 on 06/16/2023 15:17:49
Response Posted - 06/16/2023 :  17:50:37  Show Profile
Challenging is an understatement. Beautiful workmanship. Have you had a chance to sail the boat with this modification?
Response Posted - 06/18/2023 :  07:31:26  Show Profile
The new design looks really cool. Nice work!
Looking at the numbers, however, comparing a 1050# and 1250# keel weight to my fir keel at 1700#, I originally assumed that my boat would feel stiffer in a heel. But, the idea of using a bulb keel is that you put the weight where you need it - at the end of the lever arm - instead of distributing it generally around the keel.
The righting force is equal to the weight multiplied by the distance from the rotation point of the boat that matters. So if your 200# is located say 4 ft from the axis point, it’s righting moment is 800 lb-ft, not counting the moment from the keel fin. The math for calculating the exact moment is beyond this post, but you’ll know it when you feel it.
Like Scott “Islander”, I’d be interested to learn how the boat sails and how much less “tender” it is on heel in strong winds.
Buzz Maring
Response Posted - 06/18/2023 :  07:37:27  Show Profile
VERY COOL!!
Buzz Maring
~~Freya~~
C-25 SK/SR #68
Lake Dallas, TX
zeil
Response Posted - 06/26/2023 :  15:50:39  Show Profile
Wow... did not hold it for possible. Great job, hard to follow!!
Just wondering what the effect of having the weight of the new beautifully shaped bulb spread further forward and aft would have versus the discarded central located "wings".
Would it decrease Hobby-Horsing?
Would "wings", placed far aft help?
Henk & Johanna
Edited by - zeil on 06/26/2023 16:18:35
WK 727
Response Posted - 06/27/2023 :  15:03:54  Show Profile
Thanks for the kind comments everyone. The forward location of the bulb in relation to the keel is to correct the squatting of the stern. The wings were 86 pounds each (with lead shavings). By removing the 172 pounds near the aft section of the keel and adding 372 pounds with the lead center closer to the front of the keel, the boat now sits on its lines with no ballast needed to level it out. Zeil, my gut is that the more we can move weight forward, the better the performance, but I am not really sure. Hobby horsing? Great question. The length is needed to create the most efficient bulb for the design weight. I wasn't concerned about catching crab pots, this is all about performance!
Regards, John
04 Catalina 250 WK
Yanmar 9hp diesel
Edited by - WK 727 on 06/27/2023 15:41:22
zeil
Response Posted - 06/27/2023 :  18:33:22  Show Profile
Just love your design incorporating forward weight consideration thereby correcting forward ballast and with absolutely beautiful lines and execution work. Your design and work is totally professional. Thank you for sharing this
Henk & Johanna
