 Tiller type/shape for C250
sebastko
Initially Posted - 04/02/2023 :  22:58:01  Show Profile
Hi,
I'm converting wheel steering on my 1996 C250 WB to a tiller. What type/shape would you recommend?
For instance, the tiller sold by Ruddercraft, which is supposed to fit C250, looks to me like may have too much rise:
https://store.ruddercraft.com/index.php?route=product/product&path=181_32&product_id=55
If you have this Ruddercraft tiller installed in your own C250, could you please comment if it's comfortable or you'd change anything?
Any other brands/shapes that you've tried on C250 that you would either recommend or warn against?
Catalina 250WB
zeil
Response Posted - 04/07/2023 :  01:38:53  Show Profile
As far as we can tell the straight tiller is adequate. It clears the fuel compartment nicely without the rise.
Both our C250 came and have a straight tillers easily accommodating extensions and tiller tamers.
Henk & Johanna
k3fuller
Response Posted - 04/10/2023 :  09:16:15  Show Profile
I have the ruddercraft BW250 kickup rudder on mine. It's a beast and not fun to put on/take off at the ends of the seasons. I like it a lot, steers really well and it has the tiller rise. I use a tiller clutch mounted on the underside which works very well. I find it very comfortable and I think the rise helps it be at a more comfortable position for your arm and you aren't bending down.
https://store.ruddercraft.com/index.php?route=product/product&path=181_32&product_id=391
Product Code: KUCat250BW
2004 250WB #781
