 Bilge Pumps
Blowboat
Initially Posted - 10/23/2022 :  13:05:52  Show Profile
So, in theory our new boat has two bilge pumps: an electric pump and a manual pump operated from the cockpit. Theories are good...unless they are not right. We do have two bilge pumps...but the manual one is not connected! So, how do you run the hoses for two bilge pumps?
The electric one runs through the cockpit locker to the through hull on the stern of the boat. Will I need to drill another hole for the manual pump? Can they be connected and run out the same through hull?
I haven't had an electric bilge pump before so not sure how this works.
Joseph Washburn (Southport, NC)
1983 C-25 FK/TR
"Disciple Ship"
#4090
Response Posted - 10/24/2022 :  06:33:44  Show Profile
Sounds like your PO installed an electric pump and used the existing hoses from the manual pump. Nothing wrong with that. Just make sure the electric pump works and is wired properly and is not connected to the fuse panel. It should be connected directly to the battery. Its not a good idea to connect two pumps to the same discharge hose. Water can be pumped from one pump back up through the second pump and back into the boat. Some would say to use backflow preventers to prevent this but that is also not a good idea. Backflow preventers can clog or get stuck. The best bullet proof way of having two bilge pumps if you want is to run two seperate hoses and thru hulls. It could be that the manual pump rubber diaphragm has rotted and the pump no longer worked so your PO installed the electric pump. Catalina Direct has the pump rebuild kit if you want to fix it.
Edited by - islander on 10/24/2022 06:41:49
Response Posted - 10/24/2022 :  07:20:14  Show Profile  Visit Leon Sisson's Homepage
Here's a link to a post about bilge pumps from earlier this year which might be helpful:  Bilge Pump.
— Leon Sisson
Response Posted - 10/26/2022 :  07:09:41  Show Profile
<< Can they be connected and run out the same through hull? >>
they could be but it's not only a bad idea, not to make the new bilge line redundant but it's problematic ... a back flow check valve on both lines and one could malfunction at a very important time, when you need to keep the boat afloat.
And not only would you be getting water in the boat but you might be pumping it back in....
Although who knows, you might be able to find a good design..
IMHO
Edited by - redeye on 10/26/2022 07:21:02
Blowboat
Response Posted - 10/26/2022 :  18:10:08  Show Profile
Thanks everyone! I thought I had read it was a bad idea to plumb them together. Appreciate the inpu!t
1983 C-25 FK/TR
"Disciple Ship"
#4090
