 Thru hull replacement
TwistyMcFisty
Initially Posted - 10/04/2022 :  04:19:48  Show Profile
Can anyone point me in the direction of a how-to on replacing the early “volcano” thru hull with a proper one??
I just bought the boat and want to do this while it it on dry land!!
Thankyou!!!
1977 Catalina 25
Standard rig, swing keel
Outer Banks, North Carolina
Response Posted - 10/04/2022 :  05:58:53  Show Profile
In essence, you remove the old to hull valve and pipe, grind the volcano flat and install a new bronze pipe and ball valve.
Here's a link. Scroll down to "To" hull pipe vs. Thru-Hull Fitting. http://barnaclebillholcomb.blogspot.com/2017/
Response Posted - 10/07/2022 :  21:55:43  Show Profile
Catalina Direct also offers several plastic parts that can work for decades.
The actual through-hull mushroom piece
https://www.catalinadirect.com/shop-by-boat/other-catalinas/interior/plumbing/valves-thru-hulls/thru-hull-mushroom-for-12quot-or-34quot-seacock/
And the seacock ball valve
https://www.catalinadirect.com/shop-by-boat/capri-25/interior/plumbing/valves-thru-hulls/12quot-ball-valve/
Note about hose clamps:
1. Always use stainless steel clamps. Test them out using a small magnet or your navigational compass. It they’re at all magnetic, then they are NOT SS.
2. Always use two in tandem, because when one fails, you’ll have a backup clamp.
Edited by - Voyager on 10/08/2022 05:34:34
