 Re-arm auto-inflatable life jacket
Initially Posted - 07/16/2022 :  06:47:27  Show Profile
Some time ago I purchased three West-Marine branded auto-inflatable inshore life jackets during a promotional sale. They’re very comfortable and as long as you inspect them yearly, they work well.
This week in the heat, one of them went off in my parked car. The thermometer read 120°F in the parked car when I returned from lunch.
Now I need to re-arm them.
Does anybody have any experience with these, or suggestions on what OEM brand West Marine used? I imagine that another company manufactured them and stuck a WM tag on them. I need the bobbin and the dissolving pill actuator for the unit, assuming that the CO2 cartridge is pretty standard across the board.
Now looking at Defender and West, prices on-sale for auto-inflatable PDFs are $180-250 each. These were $99 back in the day.
Thoughts?
Response Posted - 07/16/2022 :  07:40:38  Show Profile
Comparing the parts, it appears that I need something like a 33g CO2 cartridge and a bobbin kit like this
Response Posted - 07/16/2022 :  08:04:31  Show Profile
Yes, Don't leave them in a hot car.....
Couldn't resist but are these re-arming kits universal? If not and they are model spesific do you have a WM model # somewhere on the jacket? That kit you are looking at says it comes with directions.
Edited by - islander on 07/16/2022 08:05:58
bjoye
Response Posted - 07/16/2022 :  08:25:43  Show Profile
I have a couple of inflatable pdfs from West Marine. The basic 'inshore' vests use the 'Leland' rearming kit. https://www.westmarine.com/buy/leland--inflatable-life-jacket-rearming-kit-automatic-24-g-1-2-threaded--6975999?cm_sp=Onsite-Recs-_-Frequently-Bought-Together-_-Navigate-PDP Check the size of the CO2 cartridge as they vary from 24g to 38g
The 'Off Shore' vests are made by Mustang and take this kit (or similar) https://www.defender.com/product3.jsp?path=-1%7C135%7C2290066%7C2290076&id=597875
I rearmed all my vests early this year, since all where out of date. The simple 'inshore' vests I think are only good for 3 years, the Mustang vests, 5 years. They don't count as official pdfs if they are out of date.
"Frayed Knot" 1989 C-25 WK/SR #5878
Response Posted - 07/16/2022 :  14:48:31  Show Profile
Originally posted by bjoye
...They don't count as official pdfs if they are out of date.
Inflatables also don't count if you're not wearing them. (Putting them on after the Coasties spot you doesn't count.)
Before the first time I rearmed mine, I put it on and pulled the cord--thought it was going to choke me! Comfortable when flat is one thing--I've gone back to a traditional jacket.
Edited by - Stinkpotter on 07/16/2022 14:56:47
Response Posted - 07/17/2022 :  04:52:34  Show Profile
My wife and I usually put them on when we arrive, one less thing to forget. And most falls off boats are at or around the dock.
When mine inflated you’re right, Dave, it’s like a boa constrictor, however, they support the back of your neck, and will turn you face up in the water.
Scott - you’re right - don’t leave them in a hot car.
Bill - I brought my old life vest to the store and they had a Leland 24gm unit right there next to the PDFs. Piece of cake to replace. Thanks all!
Response Posted - 07/19/2022 :  12:06:10  Show Profile
I had one go off in the car once, hot humid day, windows rolled up while at work. I used to have a stick-on thermometer in the car, one day it went off the scale which maxed out at 150 degrees.) Re-arm kits are not inexpensive. Now, if I think there's a chance to get wet, like working foredeck in a regatta, I'll wear a standard PFD.
DavidP
Response Posted - 07/27/2022 :  14:07:30  Show Profile
Every two years I take my West inflatable jackets to the local West store. They get the correct cartridge -- and even do the replacement for me! Its pretty straight forward as long as you get the correct cartridge.
Peter Bigelow
C-25 TR/FK #2092 Limerick
Rowayton, Ct
Response Posted - 07/27/2022 :  15:08:27  Show Profile
I just bought a Bass Pro Shops automatic inflatable pfd (Model AM 24) at Cabela's on sale for $59.99. The sale is over, but it'll be on sale again at Cabela's or Bass Pro Shop, or, if you don't want to wait, their regular price is $99.99. The recharge kit costs $25.00 and it's easy to recharge when needed. The manufacturer recommends rearming every 5 years.
Response Posted - 07/28/2022 :  10:41:12  Show Profile
I am currently rearming a pair of "SOSpenders" made by Stearns. The PFD's are about ten years old and this will be the second time rearming them. However, Stearns has discontinued the kit. I did discover that the kit is actually made by a company called Leland Gas. It was just a matter of picking the right Co2 bottle, grams and thread size, make sure you get that "automatic" kit with the green indicator.
Edit: link to WM Leland kits
https://www.westmarine.com/search?q=rearming%20kit&prefn1=manufacturerName&prefv1=LELAND
Oops.... see that Bjoye covered this above...
2005 Gemini 105Mc
PO 1987 C25 #5509 SR/SK
Tampa Bay
Edited by - Davy J on 07/28/2022 10:50:47
Response Posted - 07/28/2022 :  21:05:35  Show Profile
The Leland kit for West Marine life vests comes in an inshore version with a smaller CO2 cartridge (about 22 gms) and the larger 33 gm offshore CO2 cartridge. The bobbin or “pill” that releases the pin is what you’d have to check for size and fit.
