 WB weight? 2,000 lbs?
doublereefed
Initially Posted - 05/10/2022 :  20:18:30  Show Profile
Am I understanding this correctly? WB displacement is 3,250... ballast tank is 1,200 lbs... so the dry weight of the boat is 2,000 lbs? I need to know, having a crane give me a lift...
'95 C250 WB #61
Midway, UT
Edited by - doublereefed on 05/10/2022 20:19:05
dubedoo
Response Posted - 05/11/2022 :  08:33:13  Show Profile
2003 C250 wb boat (dry, no gear), trailer and motor = 5,100# when I weighed some time ago.
5,100# less 1,400# (est.) for trailer and 100# for motor = 3,600# for boat dry and no gear.
Never got around to weighing just the trailer but would guess that just your boat dry and no gear and without the motor would weigh at least the 3,250#.
Steve
C250 wb #702
doublereefed
Response Posted - 05/11/2022 :  19:05:37  Show Profile
Steve, super helpful. Thank you for the info.
'95 C250 WB #61
Midway, UT
Response Posted - 05/12/2022 :  08:22:58  Show Profile
For perspective, the C-250 wing keel model is listed at 4200#, which includes 1050 of lead in the keel. There are some other differences, but much is similar.
DavidCrosby
Response Posted - 05/12/2022 :  20:43:54  Show Profile  Visit DavidCrosby's Homepage
To add to this, I weighed my 250wk on its trailer, with Honda 9.9 outboard using a truck scale. The boat was mostly empty of stuff.
The trailer was hitched to the tow vehicle when weighing, so the number I am sharing is not 100%. Tow vehicle was on the drive wheel scale. Trailer with boat and motor on the trailer scale. Trailer scale showed 5,700 lbs. Tongue weight needs to be added. So I am guessing the total weigh is just over 6,000 lbs.
David Crosby "Small World"
'02 C250 WK #614
Edited by - DavidCrosby on 05/12/2022 20:45:22
doublereefed
Response Posted - 05/19/2022 :  10:17:23  Show Profile
The crane operator said I weighed in at 3,800 lbs. No OB, or rudder, mast and all rigging laying across the deck of the boat. Just FYI.
'95 C250 WB #61
Midway, UT
Edited by - doublereefed on 05/19/2022 13:13:59
