This post would be better served had I posted back in the fall. But I did not take pictures when covering the boat. A little over a week ago, I uncovered the boat and my wife said, "You should take some pictures of that skeleton you have on your boat." So, here goes.
I bought a bunch of PVC pipes that I zip tie spanning across the boat. There is no real pattern, just trying to keep the cover from sagging and filling with snow or water. I cover with a big, white, heavy duty cover that I bought at from Tractor Supply. This cover has held up really well.
Hi David, for some reason I cannot see your pictures but I too use 1”x8ft PVC pipe as a skeleton. I wrap them using Home Center string tied to the boom. I wrap a green tarp over top. I don’t cover the forward section of the boat because that’s where I place my solar panel. How do you support the pipe forward of the mast? The snow falls off the tarp and does not fill up the cockpit. It’s a nice compromise.
My mast is down for winter storage. However, if I were to attempt to cover with the mast up, I would probably have my whisker pole extend from the mast (at boom level) to the bow pulpit and continue the skeleton frame forward over that.
I have a small solar panel that I trickle charge with. Normally it hangs off the stern pulpit. When the boat is covered I mount it on a 1x4 board that sticks out behind the boat. The 1x4 is clamped to the catbird seat with a couple C-Clamps.
If you store your boat with the mast up (most probably can't), you don't need a skeleton frame. I stored my Cal 25 one winter with the mast up. I attached the spinnaker pole to the mast ring and lashed the other end to the bow pulpit and draped a tarp over it, forward of the mast. I draped another tarp over the boom. Both tarps were at a sufficiently steep angle that snow slid off them. If a C25 with an un-fixed boom isn't high enough to create a steep angle over the lifelines, you can raise the boom with a slide stop and raise the aft end with your adjustable topping lift. I don't remember for sure, but I think I also rigged a smaller tarp from the aft end of the boom around the transom to fully enclose the cockpit. The simplest way I've found to hold tarps down is to drive tent stakes into the ground.
David, for some reason your photos automagically appeared. Looks good! My pipes are laid out more like a fish bone skeleton perpendicular to my boom. I added a short board to the end of my boom to provide for an anchor for my last 2-3 “bones”. This allows me to completely cover the entire cockpit.
Over the years I have considered making my own frame. One year even drew up plans and went to Home Depot to buy PVC. I was surprised how heavy PVC is. As I remove the mast every year my design was a 3 inch diameter tube from bow to stern where the boom and a whisker pole might otherwise be utilized, then smaller diameter to be the "ribs" from center to gunnel. Anyway, between the weight and cost I ended up doing nothing. Your set up looks intriguing -- just not sure how it would hold up to heavy snow we often get here in New England.
Peter Bigelow C-25 TR/FK #2092 Limerick Rowayton, Ct Port Captain: Rowayton/Norwalk/Darien CT
Peter - rather than using 3” PVC, why not use a few wooden 10ft 1x3s screwed together? You can add 6x6 blocks on your cabintop to keep it raised up. You can probably get away with 12-13 ribs, which should cost < $200.
