At the back, I used a couple of cargo straps connecting the rear of the bimini to the catbird seat aft rails.
The front of the bimini uses the included straps. They are hooked to the same eye used for the forward connection of the cockpit lifelines. They are easily disconnected temporarily to make room for loading/unloading.
The bimini weathered several fairly strong thunderstorms on the mooring and survived without issue. So far, so good.
I've tried adhesive backed velcro for applications inside and outside the boat, and the velcro grips so tightly that it pulls the adhesive off whatever it's stuck to. You could sew velcro to the fabric, but when used outside, velcro deteriorates in 2-3 years of sun exposure and needs to be replaced. Don't try to sew on adhesive-backed velcro. The adhesive gums up the sewing machine needle.
IMO the best solution would be to install a lapped zipper. The zipper on your trousers is a lapped zipper. The fabric cover not only looks nicer than a bare zipper, but it also protects it from the sun.
If you don't have a sewing machine yet, you should consider one for simple boat canvas projects. I have a light weight machine and a heavy duty Sailrite machine, but use the light weight machine the most by far. My light weight machine is a Brother CS 6000. It's easy to use and has a system that helps thread the needle. Once you learn to use it, you'll also find it handy for mending clothes occasionally and sewing on buttons.
Love the simple installation, looks and serviceability especially the fact that NO holes need to be drilled... it is a great out-of-the-way platform for solar panels
Unfortunately the bimini tops are presently unavailable
Henk & Johanna "Floating", a few off your "barnacles". "Someday Lady" '95 C250WB #151 ('03 - 2016) "Sea ya" 30ft Bayliner (04-2018 - 09-2018) "Mariah" '96 C250WB #191 (05-2019 - 15-05-2023) "Lady J" '00 C250WK #499 (05-2021 - 09-2022)
This is very similar to the design of the bimini that came with our boat, custom made by a shop in the puget sound. The seam for the backstay on ours is a typical vislon zipper in a large size.
I'd love any ideas for changes (or different designs) that would be better for trailer-sailing. It takes us longer to get the bimini assembled and set up than it does to raise the mast. Wrestling the bimini out of the cabin, or working around the bimini frame while it is stowed in the cabin, is also a huge hassle.
