 Tiller Needed
Initially Posted - 11/07/2021 :  17:50:25  Show Profile
Anyone have an extra tiller in good condition for an '89 C25? Mine broke during Ida a couple of months ago.
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Edited by - GaryB on 11/07/2021 17:50:47
Response Posted - 11/07/2021 :  20:53:50  Show Profile
Gary, that must’ve been quite a story. Were you somewhere sailing out in the full fury of the storm or was your boat just sitting on its mooring thrashing in the wind?
How badly did it break? Because they’re laminated you might be able to repair it given enough epoxy.
Here’s a replacement unit https://store.ruddercraft.com/index.php?route=product/product&path=181_32&product_id=54. Not cheap though…
Another offering
https://anytiller.com/stock-tiller
Edited by - Voyager on 11/07/2021 21:13:45
Response Posted - 11/07/2021 :  23:11:49  Show Profile
It was in the slip. Snapped it off where it comes out of the mounting hardware.
I keep my tiller tied off to keep the rudder from swinging back and forth and putting wear and tear on the pintles (I leave a little slack but not much). I didn’t even think about when the storm was coming.
The wind should have been coming from the South which would mean there wasn’t hardly any fetch as the waves would have been coming down a short slough and the cross dock should have blocked some of the waves but apparently it was worse than it should have been. The marina staff told me several people stayed on their boats and swore they would never do it again. Scared them pretty bad.
I’ll get with Ruddercraft and get one ordered. Is varnished good enough or should I go with the varnish and epoxy. I’m going to sell the boat soon if that makes a difference.
Thanks for the info.
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Edited by - GaryB on 11/07/2021 23:12:58
Response Posted - 11/08/2021 :  06:29:31  Show Profile
Gary, yes - glad you weren’t on board. Even a small patch of water can become a washing machine in hurricane-force winds.
IMO, the varnish and epoxy finish is designed to last several seasons without having to refinish. But, if you’re planning to sell soon, plain varnish should work fine for most of a season.
Edited by - Voyager on 11/08/2021 06:31:39
Response Posted - 11/08/2021 :  07:13:57  Show Profile  Visit OLarryR's Homepage
Gary - Surprised the tiller broke just being dockside. Something for me to think about when an impending storm is approaching.
Larry
Response Posted - 11/08/2021 :  07:54:40  Show Profile
Trying to imagine the dynamics... It seems a boat heeling violently back and forth (from wind on the mast as well as washing-machine waves) would be trying to break either the tiller or the rudder blade--you got the less expensive outcome of the two! In the slip on a protected river, I used to tie my tiller up to the backstay, but in an approaching major storm, I removed the rudder.
The Ruddercraft deal looks better than what I paid somebody (maybe CD) around 16 years ago when someone lost their balance and sat on my tiller.
Edited by - Stinkpotter on 11/08/2021 07:55:10
Response Posted - 11/08/2021 :  13:37:50  Show Profile
Dave, that tiller is still going strong these many years later. I remove the tiller and rudder from the boat each winter to make sure they’re both intact for the following year.
Last year I traced the tiller onto a piece of 5/4 oak board just in case. I glued the two thicknesses together to get the right size. It weighs a ton, but it’s a fine back up.
Response Posted - 11/08/2021 :  19:40:06  Show Profile
I was surprised too. Normally when a storm is approaching I move the boat to another marina that’s totally protected but this storm just didn’t seem that big of a deal and based on its track I knew the winds would be blowing from the South and blowing from the near shore so didn’t worry about it much.
Unfortunately I forgot about the rudder being tied up. Thinking about it just now, I really didn’t take a close look at the rudder to see if it might have been damaged as well. Better get down there this weekend and check it out.
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Edited by - GaryB on 11/08/2021 19:41:09
cudamank
Response Posted - 06/01/2022 :  14:30:27  Show Profile
Someone had a post about an emergency tiller made out of a wheel barrow handle. When refinishing my tiller, ( a project that took way to long on my part) I used one for a temp tiller as the boat was at a marina at the time. Have to say it worked quite well.
1982 Catalina 25 SR FK
"Jenny"
Response Posted - 06/01/2022 :  18:29:35  Show Profile
There is a place in Quincy MA called Marineparts Salvage (they are on-line) have every imaginable item including a trailer filled with tillers. Reasonable prices -- I have bought spares there -- might want to check them out. They do ship all over the world.
Peter Bigelow
C-25 TR/FK #2092 Limerick
Rowayton, Ct
Response Posted - 06/01/2022 :  19:14:16  Show Profile
Thanks Peter! I'll check them out.
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
