In order to store galley pots and pans on the shelf below the stove we would like to create an access opening in approximately the marked up location
I will make a template for the exact location of the opening
My questions
1) How would you prevent rough/splintered edges, markings and scratching the adjacent surface 2) What tools would you use for cutting the opening 3) How can one best prevent dust from flying about 4) Tools to clean-up the finished edge
Henk & Johanna "Floating", a few off your "barnacles". "Someday Lady" '95 C250WB #151 ('03 - 2016) "Sea ya" 30ft Bayliner (04-2018 - 09-2018) "Mariah" '96 C250WB #191 (05-2019 - 15-05-2023) "Lady J" '00 C250WK #499 (05-2021 - 09-2022)
Henk, No photo with your post so not sure of your workspace but if room allows I would tape (painter’s tape) the perimeter outline to be cut, mark your lines clearly on the tape and use an oscillating tool with a half-circular cutting blade for the straight edges. Radius the corners by drilling them out. As for dust, have your first mate hold a shop vac nearby. You will have dust but a rotary tool would create far more. Not sure how you want to finish the edges or if you are considering any type of trim, but a sanding block would be a first step to cleaning the edges. Not very innovative but well tested. How are you planning to finish or cover the edges?
Hi Henk, when I first read your question I thought about a vibrating tool (Finetool) with a carbide blade or a Sabresaw with a metal-cutting blade (fine teeth). I’d use a plug-in tool rather than a battery-based tool to get higher speed and faster cutting. The benefit of a sabresaw would be that you can cut a smaller radius. You can also drill holes at the four corners to make a tighter radius. I second using painters tape to minimize tear-out or splintering on the edges. And use a shop-vac to keep the dust down. I’m not sure how you’d finish the edge - would you square them off or round them over? I see you’d frame the opening with teak and melamine, so it’s a minor point.
Henk, you have enough experience to know what tools you are comfortable with but I agree with Bruce that a Sabresaw with a fine blade might be easier to manage because you are positioned directly "above" your cutting line and thus easier to maintain a near perpendicular edge. It is scary to cut into your boat; just think it through and go carefully.
Henk, rather than make your first cuts right on the line you’ve drawn on the cabinet, try a test cut inside the rectangle just in case the saw gets out of control. You can always make adjustments then try again until you get it worked out right. Once you can control the blade accurately, only then try your final cuts. Again, I would be inclined to make a jig or a wooden guide for my saw to follow rather than doing it freehand. Never know when you might get a wicked case of hiccups!
Thank you guys for providing alternatives for tackling "finished surface fiberglass cutting".
To make sure, I'm planning to obtain an exact location template of the opening from the other boat. (the approx hand drawn location lines shown in the photo are only on the photo)
It'll be my pleasure to document and provide photos.
It takes some patience but you can make a fairly clean cut using a Dremel tool and one of their thin diamond wheel cutters. That’s how I cut a rectangle to install a new switch panel in front of the sink (photos on my website). I forget how thick the fiberglass was but believe it was around 1/8”. The Dremel cuts well for thin thicknesses using speed versus torque but as thickness increases, then it may bog down.
First drill a hole that the saw blade will fit in. If you are seeking rounded corners you could drill four holes to achieve the contour. Then as people have stated use the highest speed/finest tooth saw for the smoothest finish. I would consider looking at CD for a drawer or door that might look similar to what you have already for cosmetics. If not, you can get material, similar to auto door edging to make the opening smooth tot he touch.
Peter Bigelow C-25 TR/FK #2092 Limerick Rowayton, Ct Port Captain: Rowayton/Norwalk/Darien CT
I’d recommend rounding off the corners if possible. Square corners can create a stress point that may lead to cracking later on. A hole from a 1/8” to 1/4” drill bit should suffice to round the corners and reduce the chances of cracks forming.
Following much appreciated advice I took the plunge and cut the service opening below the stove.
From our other Catalina we made a cardboard template and copied the exact location and size of the opening to this boat
Using masking tape we then copied the outline on the tape-off area. Before drilling and cutting we used a plastic shopping bag and taped this to the inside of the galley counter to eliminate as much dust as possible
Next we drilled 1/4" holes in all 4 corners. With the oscillating tool using the half round cutting blade we cut through the 1/4" - 3/16" fiberglass. Using a wood type file and sandpaper the corners and edges were rounded and smoothed. I'm very happy with the result and happy with super easy access to an existing storage area.
Cutting into exposed, interior fiberglass is scary business. Make sure it is in the right place and do it only once. Preparing and taping the "to be cut edges", forestalled any splintering which were then filed and sanded smooth.
Thank you guys for all your help!!
A new Velcro "teak-lined melamine cover", nicely hides the service access opening
This is the template used, It was copied from our '96 C250 WB who is equipped with the galley settee side access port.
