As Steve suggested, a quick search on Amazon for 12v LED festoon bulbs turns up over a hundred, even after filtering for 4* and free shipping.
Here area a couple other possibilities, depending upon how much light you're looking for (and how much work you're up for).
A few years ago, I converted four of the old square plastic Catalina cabin light fixtures to LED by using small rectangular flat panels of LEDs which work off 12.VDC. As I recall, I zip-tied them in place of the original bulb socket and wired them to a new rocker switch which sorta fit the original hole with a bit of carving. I also added red LEDs, but that took a lot more work.
For a different boat, found some better looking cabin light fixtures — new stainless steel ones with clear plastic Fresnel lens, and a few old teak and brass lights with glass lens. I converted those to white/red LEDs by soldering individual LEDs onto small circuit boards and installing SPDT ON-OFF-ON rocker switches.
Just a reminder, there's a significant difference in color between "warm white" and "daylight white" LEDs. I have both, and much prefer the "warm white" for cabin lights.
On the port and starboard settee sides, I purchased two West Marine surface-Mount fixtures. They produce a warm white light and also offer a red light option. Here’s a photo of the lights. This is very bright In some other fixtures I replaced the bayonet-style incandescent bulbs with the equivalent LED 12VDC automotive bulbs. 1157s fit well physically however it had to check polarity.
I tried a LED 2”x2” square with 16 LEDs that I crazy-glued into the fixture and crimp-connected the wires. That worked well enough but was not as bright as the other options.
I also made a light fixture for under the quarterberth that consisted of 2 LED trucker license-plate lights glued onto a 4”x4” cutoff piece of Azek with a toggle switch attached. This is similar .
When LED's first came on the market I recall reading that price differences between off-the-shelf and "marine" LEDs was due to electronics to minimize interference in VHF reception - worth noting, a marketing ploy or a non-issue with todays LEDs? Have any of you noted any issues?
I have replaced , all but 1 light with LDE. call me "cheep" but I went to the Truck stop out on the Hwy. yes , they had all but 1 that I needed. Dave B 250 1999 Catalina.
Gerry, yes, to answer your question, I bought a 2nm Nav Light from Dr. LED early on that was a Festoon base for my Aquasignal stern light fixture and it generated a TON of VHFand FM “hash” (aka static), so the light was absolutely unusable. I returned it and the vendor was very apologetic. It seems that there’s a built-in power supply chip that converts 12VDC power to an AC voltage that’s more appropriate to the LED configuration. That chip generated a lot of radio frequency noise. Very unpleasant. Today, most vendors have solved that problem.
Removed both overhead directional cabin fixtures. BTW while open between deck and liner checked for moisture/dampness around compression post and electrical deck outlet... all is, beside being a bit dusty, bone dry
Replaced overhead fixtures with bright, warm white, on/off dimmable LED light fixtures.
Henk & Johanna "Floating", a few off your "barnacles". "Someday Lady" '95 C250WB #151 ('03 - 2016) "Sea ya" 30ft Bayliner (04-2018 - 09-2018) "Mariah" '96 C250WB #191 (05-2019 - 15-05-2023) "Lady J" '00 C250WK #499 (05-2021 - 09-2022)
