Someone can probably measure it but they need to know whether you have a tall or standard rig, eagleeye. Create a "signature" for yourself similar to this: "1985 C25 SR/FK." It will give folks the basic info they'll need to answer most questions.
Toss a ball of string or line up and over the spreader then pull both ends down to the base. Mark the line then pull the line down and divide the length in half.
Yes, I inspected the “Manuals and Brochures” section at the left of the Forum pages, but did not see any dimensions written on the charts.I reckon that it’s about 12 ft to mine (I used my extension ladder to reach) and that’s what I recall…
Depends on your requirements but a thought....I've recently had good use of an app on my iPhone (2-3 generations old) that measures distances using a light pointer to mark the end points of the distance to be measured. Works rather well within a limited range if not too much external light interference.
All good suggestions. At one point, I attached my tape measure to the main halyard and ran it up to the spreaders. Unfortunately, I cannot recall the measurement. Since the mast is 28' (I think), is it a safe assumption that the spreaders are close to half way up the mast, making the spreaders' height about 14'? This seems to be close to Voyager's guess.
Just curious... How precise do you need to be? (You never mentioned why you were asking.) Measuring on a photo of my SR taken from a distance, they appear to be just about precisely half-way up from the cabintop. So 14' is probably well inside of a foot from the actual.
I'm using the technique described in the video pasted below to take down the mast. If you watch the video you'll see why I need to know the spreader height.
Wow! There’s always another way to skin a cat. From what I saw in the video is the A-frame needs to put the hoisting strap at the mid-point or balance-point of the mast.
The question I have is: how do you ensure that the strap stays put on the mast and doesn’t slip?
Apparently it sits just below the spreaders.
If, however, the mast begins to invert slightly, it’s possible that the strap will slip and capsize the mast.
I also felt badly for the lady whose job it was to lift the mast out of the tabernacle. It seemed heavy and slightly unstable.
I assumed that the A-frame was stabilized by a forestay and a backstay tied to the chainplates?
Many of our members have used a system like this to raise and lower their masts. This fellow even uses it to lower his mast while underway, to pass through a low bridge. Plans for it can be found in our Tech Tips. https://www.youtube.com/watch?v=r33VCObNroY&t=2s
I've recently purchased an '81 tall rig and I've measured the spreaders to be about 15' from the mast head... pretty close to the mid point on the mast. As others have stated, we don't know how precise you need to be so I'll warn you that I was after ballpark measurements rather than precision. My mast is down so if you need a more precise measurement from a tall rig boat I can get it for you, just let me know.
Paul in SLC, UT 1981 C25 TR/FK
Paul 1981 Catalina 25 TR/FK Soon to be named either Fiddler's Dream or Fool's Errand depending on what it takes to get her into shape
