 Transferring photos from Shutterfly to this site
zeil
Initially Posted - 10/02/2021 :  10:40:52  Show Profile
Can someone provide insight...
We seem now to have problems transferring photos from Shutterfly to our Association Forum
To transfer an image from Shutterfly to this site: click, drag from Shutterfly and drop it between "insert image", only shows the following...
However now to transfer a photo from Shutterfly to this site: click, drag and drop the image from Shutterfly to our forum without using "image insert", the following shows up
https://uniim1.shutterfly.com/render/00-Kql8nYq3EoFBfyIX1pbXmPEsSaOlh7ozkpg7Qycnl5Ca8ScICuCrTEH-XcjylIU3aAUrgnwgvQnZ_1RWb7NZPA?cn=THISLIFE&res=medium&ts=1603925134
Appreciate help...
Henk & Johanna
Russ.Johnson
Commodore
Response Posted - 10/13/2021 :  21:05:43  Show Profile
Hi Henk,
Let me try
I’m sorry, I could not get the Shutterfly link to work.
I was able to copy the photo to the gallery, then post the link below
https://www.catalina-capri-25s.net/cgi-local/MBRimg.cgi?+1002+5297
Russ Johnson
2005 C250WB Hull 793
Edited by - Russ.Johnson on 10/13/2021 21:26:55
zeil
Response Posted - 10/15/2021 :  18:28:22  Show Profile
Russ thanks for your help but...I still do not seem to be able to post a photo
Here is what I did in the past
I use a Macbook Pro
I open and sign into my account at Shutterfly and select one of my albums
Then I search for a photo I want to use and click on it
Next, I open a NEW WINDOW and sign onto our Catalina Association Website and open to right topic (using Firefox web browser both Catalina and Shutterfly windows are side by side open)
Then if and when I want to post the photo I select from the menu "insert image"
Now I go back to the open Shutterfly website and select the photo I wish to use. I double click on it, drag and take the photo over to Catalina's website and drop it in between the brackets "insert Image".
When I preview the photo only the following shows
Repeating the same procedure I go back to the Shutterfly site to copy a photo, I click, hold and drag and maneuver the curser and drop the photo OUTSIDE the "insert image", brackets and this time just the address shows up.
https://uniim1.shutterfly.com/render/00-Kql8nYq3EoFBfyIX1pbXmPEsSaOlh7ozkpg7Qycnl5CFbGb5KzU9fvXnba4GpaJd5cYdfB3jRoL_VZILaXEufg?cn=THISLIFE&res=medium&ts=1603925129
By clicking on the above the right photo will now appear but only the address, not the photo, will stay in the text
It seems that something is not working on our forum side of things but... I possess little computer expertise
In the past I've done the click, hold, drag and drop on my computer successfully for a long time.
What do I do wrong?
Henk & Johanna
Edited by - zeil on 10/16/2021 13:25:10
Response Posted - 10/16/2021 :  21:56:01  Show Profile
Here’s a test using the URL above
I get the same thing, a little faintly outlined square, not a picture.
As I recall the [ img] === [ /img] command sequence needs as its argument (the === stuff) a URL that ends with the file name extension “.jpg”. Without that file name extension ending, the img command doesn’t know what to do with the information.
Is there any way to force Shutterfly to produce a .jpg URL filename that you can insert into the Forum code?
If not then your best bet is to use Russ’ technique of capturing the photo from Shutterfly, copying it to the Forum photo gallery, then posting it to your comments.
Edited by - Voyager on 10/17/2021 06:17:19
zeil
Response Posted - 10/19/2021 :  10:07:04  Show Profile
Thank you for your help David and Bruce
Its ever so frustrating not to be able to post photos, as I did for years, in one step from Shutterfly to our forum.
Using our Photo Gallery, I finally succeeded, is an alternative but seems a long way around to post a few photos
How or what do others do/use to simplify the posting process?
Henk & Johanna
Response Posted - 10/19/2021 :  13:28:17  Show Profile
I use Flickr for storing photos but I right click on the photo I want and a box opens with some choices. I copy(left click) on 'Copy image address' then go back to the forum and 'Paste' it between the img. brackets. This is on a Windows computer but a Mac should work somewhat the same, I think.
Edited by - islander on 10/19/2021 13:32:43
Response Posted - 10/19/2021 :  13:31:44  Show Profile
I just did this on your photo.
zeil
Response Posted - 10/22/2021 :  09:49:48  Show Profile
Thanks Bruce and Scott for suggesting Flickr which seems easy to use for posting photos to our forum
Russ suggested, as an option, to post images using our photo gallery. But... it seems that I get lost with all the steps before I even can find the right image to post. Not complaining though and grateful for the time Paul (Britinusa) and others spent around 2013.
However... is it now a good time to take a look by some fresh young tech people to provide, incorporate an up-to-date industry wide synchronized approach
I really regret the use and loss of my substantial 15 year photo inventory at Shutterfly
Henk & Johanna
Edited by - zeil on 10/22/2021 14:19:15
Russ.Johnson
Commodore
Response Posted - 10/22/2021 :  14:55:30  Show Profile
Henk,
I did some testing, but no luck.
Created a Shutterfly account.
Uploaded a test photo.
Double-clicked on the photo to view the properties.
At the bottom of the page, Shutterfly has a "Share" button.
On the Share Photo page:
Select "Create Link"
I shorter link displays, but the photo does not render.
https://link.shutterfly.com/PNz0Kquyzkb
Russ Johnson
Edited by - Russ.Johnson on 10/22/2021 15:11:26
zeil
Response Posted - 10/22/2021 :  17:00:30  Show Profile
Thanks for follow up Russ
Using your link https://photos.shutterfly.com/story_invite/edab8d27-17a4-47c4-abc1-5f41d7119a93/full/1714357836612027
Resulting in the above
Henk & Johanna
