 Hanging stuff on bulkhead
NCBrew
Initially Posted - 12/08/2020 :  13:48:57  Show Profile
I have a set of fishing rod holders that I need to attach to the bulkhead.
Does anyone know what I can use to attach the holders?
I do not want to use screws even though it is above the waterline.
1998 Catalina 250WK
Ravaging
Albemarle Sound,NC
I spent most of my money on boats and beer, the rest I just wasted.
Enchantment II
Response Posted - 12/11/2020 :  11:20:27  Show Profile
I have had the same problem trying to attach velcro on the bulkhead in the cabin. I recently used Alien tape to the bulkhead. I used it to secure the velcro to my solar controller. So far it is holding. We will see.
Joseph Henderson
82-CAT 25 TR SK
glivs
Response Posted - 12/11/2020 :  20:04:16  Show Profile
Are you referring to the wall dividing the cabin and the head? Your reference to "above the waterline" suggests you may be referring to something else. ??
Response Posted - 12/12/2020 :  23:28:45  Show Profile
You mean the aft exterior face of the cabin? (That is a bulkhead, but most "bulkhead" discussions here are about the interior.) Are these rod holders for storage or for fishing, and exactly where in/on the boat?
Exterior hardware that gets any stresses generally should be through-bolted--not screwed on--and bedded with caulk or butyl tape.
Edited by - Stinkpotter on 12/12/2020 23:29:28
Response Posted - 12/13/2020 :  20:16:30  Show Profile
I'm also unclear about what you are attaching to. My understanding was the bulkhead was the wood panels separating the sections fore and aft in the boat.
I've had good luck using small, short stainless steel machine screws attaching items to the fiberglass liner. I predrill a hole in an innocuous place to check the correct drill size for the screws Im using. The drill size needs to be very close to the screw size. it the holes are too small the screws crack the resin as they go in. i put tape on the drill bit to make sure Im drilling to the correct depth.
Some people fill the holes with an epoxy before screwing in the screws to seal the holes and prevent water ingress into the liner. There are several thickened two part resin glues out there.
NCBrew
Response Posted - 12/21/2020 :  06:06:51  Show Profile
I am referring to the inside of the boat. Between the bow and the sink area
1998 Catalina 250WK
Ravaging
Albemarle Sound,NC
