 Aluminum T-Track for mast Spinnaker car
Initially Posted - 10/14/2020 :  10:46:55  Show Profile
anybody recommend a source for 1 inch t-track for a spinnaker ring car?
any company product you would suggest?
Thank You
regards.ray
Response Posted - 10/14/2020 :  16:39:28  Show Profile
Hi Ray, here’s something like mine.
Schaefer makes it. It’s not cheap, about $50 for a two foot length
https://www.shopsoundboatworks.com/sc1siant2.html
keats
Response Posted - 10/14/2020 :  17:54:12  Show Profile
How long a piece did you need Ray? I picked up about an 18" piece at a chandlery some time back and I don't see myself ever using it, or all of it.
Edit: I should mention it's stainless steel.
Tim Keating
1985 C-25 TR/FK #4940
Midsummer
Lake Don Pedro, CA
Edited by - keats on 10/14/2020 19:37:46
Response Posted - 10/19/2020 :  04:59:28  Show Profile
<< How Long >>
Tim, I don't really know I've just begun the process of learning. Eme at raymondswords at gmail and we can discuss.
I emailed you through the forum
Edited by - redeye on 10/19/2020 10:53:02
keats
Response Posted - 10/19/2020 :  12:10:54  Show Profile
I just emailed you Ray.
Tim Keating
Midsummer
Lake Don Pedro, CA
Russ.Johnson
Commodore
Response Posted - 11/20/2020 :  01:28:44  Show Profile
I love Garhauer Marine. They are the OEM supplier to Catalina Yachts for blocks, etc.
I have ordered through their website, kinda clunky, but it’s worth it.
Home page
https://www.garhauermarine.com/products
Track (1-inch)
Looks like it’s Aluminum, but you would have to call
https://www.garhauermarine.com/track-blocks-accessories/t-track/t-track-1-wide-tt-1.html
Russ Johnson
2005 C250WB Hull 793
Sailynn
Response Posted - 11/22/2020 :  00:06:03  Show Profile
Like Russ Johnson, I buy from Garhauer
Lynn Buchanan
1988 C25 SR/WK #5777
Sailynn
Nevada City, CA
Response Posted - 11/23/2020 :  12:52:16  Show Profile
Length will depend on how you plan to use the pole. If you do not plan to store the pole vertically against the front of the mast, then 2' should be plenty. If the former, then probably 10 ft plus a stationary ring below the track to secure the bottom (forward end) of the pole. When flying a spinnaker, you want the pole to be fairly close to the boom, above usually, or below, depending on the size of your spinnaker, so the track doesn't need to be very long. Many people do not use a track at all. most of the time, you want the pole to be level.
DavidP
