 Sail slugs
Donna-Atica
Australia
Initially Posted - 11/04/2019 :  15:41:28  Show Profile
Hi Guys and Gals
I have noticed a few sail slugs are missing on my mainsail
I bought some but now I’m having trouble mounting in the mast .... Is that small round pin thingy something you have to turn as its fully stuck I cannot turn it or push it in any direction
Any suggestions greatly appreciated
Thanks again
Donna
Donna-Atica
Catalina C250 WK 2005 #825
Response Posted - 11/04/2019 :  16:46:42  Show Profile
Small round pin thingy......well I'm stumped.
Edited by - islander on 11/04/2019 16:48:32
whk1965
Response Posted - 11/04/2019 :  17:11:06  Show Profile
Use pliers to free it up
Bill Knowles
Response Posted - 11/04/2019 :  17:22:17  Show Profile
Not sure about the C250, but most sailboats have a place in the mast slot where the slot widens enough to put sail slides in. Sometimes the widened slot is covered with a metal plate, so the slides won't fall back out. The widening is usually just above the boom. Find that place, remove the cover plate, and you should be ok.
Response Posted - 11/04/2019 :  18:54:33  Show Profile
Are you talking about a sail track stop? Looks like the photo below. If so you should be able to loosen (unscrew) it with pliers or channel locks then slide it up or down to the mast gate ( where the slot gets wider) and remove it. If its really stuck try some PB Blaster on it.
Here is one just above my goose neck
Edited by - islander on 11/04/2019 19:01:39
Response Posted - 11/05/2019 :  07:34:18  Show Profile
In Scott's photo, you can also see some "gate plates" covering the opening to the slot, as Steve describes. Each has three screws that are threaded into the mast, so should be fairly easy to remove and reset. These are owner modifications, so not on all boats.
Response Posted - 11/05/2019 :  08:26:53  Show Profile
Easily mistaken but in the photo that is the fixed boom goose neck that has the 3 screws. Catalina by 1987 no longer used a sliding goose neck but instead screwed it to the mast at a fixed height. Regarding the "gate plates" I did install one that is further up the slot just out of the photo. Not all slug openings were cut the same. Mine was on one side only so I only needed one gate plate. I guess it depended on what worker was doing the cutting on that day. By the way I use that sail track stop to hold the slugs up above the gate plate when I remove the sail allowing me to have 2 hands to remove the gate plate screws. Don't want to drop them.
This is how mine is but others might be different.
Edited by - islander on 11/05/2019 08:32:33
Response Posted - 11/05/2019 :  11:38:04  Show Profile
Yup--I didn't look closely enough to notice the gooseneck was right there. I thought I was adding to what Steve mentioned--ended up muddying it up. I now recall my gate plates (like what CD now sells) had just 2 screws.
Russ.Johnson
Commodore
Response Posted - 11/09/2019 :  00:28:18  Show Profile
Donna,
I have a C250WB Hull 793, so my rigging should be close to yours.
Here's some links to Catalina Direct.
First, I think your "Sail Track Stop" is stuck.
It's threaded and use a wrench.
The photo from Catalina Direct uses the whole page.
Sail Track Stop Threaded
https://www.catalinadirect.com/shop-by-boat/capri-26/rigging/standing-rigging/spar-fittings/sail-track-stop-threaded-c-250-cp-26-c-270-c-28-c-34-c-36/
Next, the "Sail Slides" or Sail Slugs are the round ones.
There are flat ones, but they don't fit.
Sail Slide, Plastic & Shackle
https://www.catalinadirect.com/shop-by-boat/not-a-catalina/trailerable-boats/sail-slide-plastic-amp-shackle-set/
Russ Johnson
2005 C250WB Hull 793
Edited by - Russ.Johnson on 11/09/2019 00:35:26
Donna-Atica
Australia
Response Posted - 11/11/2019 :  02:20:45  Show Profile
Thank you all for your help much appreciated it turns out that sail track stop was fully stuck so yes got pliers out with a bit of help to loosen. Now my Sail has new slugs and Iooks so much better under sail
Thanks again
Donna
Donna-Atica
