 Spreader seizing wire question
john.adlam
Initially Posted - 08/07/2019 :  11:28:55  Show Profile
Can anyone help with a photo or some instructions on how the stainless steel seizing wire is wrapped around the upper shrouds/spreader end cap?
This new to me boat came with the upper shrouds completely disconnected from the spreaders. I'm replacing all standing rigging and wondering if there is a right way to do it rather than just wrapping the wire around the shroud and end cap/spreader a bunch of times.
John Adlam
1981 C25 "Valley Girl" #2500 SR/WK
1982 C25 "No Stress Express" #3218 SR/SK
Boise, Idaho
Response Posted - 08/07/2019 :  12:48:24  Show Profile
There is a right way. The seizing wire gets routed through the spreader first through the two holes on the top and bottom of the spreader then the two tails get wrapped around the shroud wire. This wrap has to be loose so the shroud can slide through the seizing wire so it doesn't pull the spreader up or down when you tack. I layed a toothpick along side the shroud then wrapped the seizing wire around the shroud and the toothpick. After just remove the toothpick and the loop of seizing wire is perfect.Here is a diagram of how it all goes.
john.adlam
Response Posted - 08/07/2019 :  14:07:01  Show Profile
Thank you very much for the clear instructions on how to do this Scott! Much appreciated!
John Adlam
Boise, Idaho
Edited by - john.adlam on 08/07/2019 14:08:25
Response Posted - 08/07/2019 :  19:59:45  Show Profile
Not sure I agree with Scott... I wrapped the wire a couple of turns around the shroud, not loosely, to add some friction to minimize the movement of the spreader tip up or down. I think I got that from a rigger... It's important to maintain the spreader angle in order to stabilize the shroud tension. Each time you tack, you want the spreaders to end up holding the shrouds at the same angle as they were before--not sliding up and down.
Edited by - Stinkpotter on 08/07/2019 20:01:39
Response Posted - 08/07/2019 :  20:35:00  Show Profile
If we're taking votes, which we do often here, I vote with Scott. I don't know of any particular positioning of the spreaders that is recommended, but common sense tells me that they should be symmetrical. If they're loose, they aren't going to self-adjust upwards. They'll only adjust downward. Moreover, I don't know that the precise angle is critical. My instincts tell me that by leaving them slightly loose, they'll settle into a position that is symmetrical and structurally sound.
If you wire them tightly, one might loosen in time, and the other might not. Then one will sag and the other won't, leaving them asymmetrical. It makes sense to leave them the latitude to self-adjust.
Response Posted - 08/08/2019 :  03:59:23  Show Profile
I got that information from CD when I called them to order all my new standing rigging. They told me how to do it. They said you don't want the spreader constantly moving up and down causing wear and possibly breaking the sockets or wear on the spreader. Made sense to me. They also said that the purpose of the seizing wire is to keep the shroud in the cap slot. It's not meant to support the spreader.
Edited by - islander on 08/08/2019 04:31:03
Response Posted - 08/08/2019 :  13:31:35  Show Profile
I’ll defer to CD. But to Steve’s point, if a spreader slides down, that shroud will lose some tension. My seizing wire didn’t prevent that—it just added some friction. I recall using a boat hook a few times to adjust one. So maybe it wasn’t that effective.
Response Posted - 08/08/2019 :  17:48:37  Show Profile  Visit Leon Sisson's Homepage
The spreader should bisect the angle formed by the upper shroud at the spreader tip.  Any deviation from that angle will tend to force the spreader farther in the direction of the larger angle.  Any such movement will reduce shroud tension (while putting additional strain on spreader and socket).
How tightly the spreader needs to be secured to the shroud may depend in part of the weight of the largest waterfowl likely to land on it.
— Leon Sisson
Response Posted - 08/09/2019 :  05:57:03  Show Profile
