 Replacing aft panel to battery compartment
vdotmatrix
Initially Posted - 07/23/2019 :  19:57:43  Show Profile
I had to remove the remote and control cables from the old motor and had to remove the aft panel.
The bottom is fairly rotted,
https://www.amazon.com/photos/shared/SIzX6jQ5SAWr_nLS_2fzqw.rEHTqoN_84msfv4szBpUFa
I want to make another panel with a convenient hatch with flag hinges and not that pain in the @#$ hatch that you have to lift up and wrestle with.
Has anyone used anything other than plywood to replace this thing?
vdotmatrix
Response Posted - 07/25/2019 :  05:43:34  Show Profile
Bump
whk1965
Response Posted - 07/25/2019 :  15:34:01  Show Profile
Don't need to replace unless you want to, not structural.
Bill Knowles
doublereefed
Response Posted - 07/25/2019 :  15:41:25  Show Profile
vdotmatrix... you solved a problem for me. I had no idea that whole panel came off. I need to redo the battery trays and an bunch of cabling... was thinking I had to do the whole thing through that door. Awesome pix, good luck on the project.
'95 C250 WB #61
Midway, UT
vdotmatrix
Response Posted - 07/25/2019 :  17:34:04  Show Profile
Man I would like to do something about that ridiculous battery access. It is so lame. You have to lift it up then pull it out but you can't because the cushions are there[quote... Marine plywood?]Originally posted by doublereefed
[/quote]
Response Posted - 07/25/2019 :  21:04:42  Show Profile
I wouldn't assume that. I never left the slip with that panel removed. I think it helps stiffen the hull from lateral flexing, especially in a heavy blow.
However, I agree that a little rot at the bottom edge of the panel would be harmless. If you really want to fix it, a little grinding away the rot and fiberglass/epoxy mat in the right place should make it as good as new.
Rick S., Swarthmore, PA
PO of Take Five, 1998 Catalina 250WK #348 (relocated to Baltimore's Inner Harbor)
New owner of 2001 Catalina 34MkII #1535 Breakin' Away (at Rock Hall Landing Marina)
vdotmatrix
Response Posted - 07/26/2019 :  04:51:48  Show Profile
That would be much more involved than just tracing the pattern and making a new pieice. Besides The purpose of the OP was to ask about a suitable material and to enlarge and make the battery compartment hatch a better more accessible design
