As I needed a larger electric cooler than the standard ice box as well as more storage space instead of digging stuff out of the bins under the seats, I decided to close the space under the counter and install doors and a shelf. The project was really easy. I used a melamine board for the face and doors, recessed handles and piano hinges so that it would look quite similar to the cupboard under the sink. The shelf is plastic covered wire 12 inches deep that I bought as is at Home Depot. To keep the beverages fresh, I got a 12v cooler that I place under the stairs.
I was a bit worried about using melamine instead of marine grade plywood. However, after a winter of bitter cold and humidity, the whole assembly showed no signs of problems. If it ever does, replacing the front and doors would not be a large investment.
Daniel Marion Zendo Cat 250 WB 2001 Hull #592 Valleyfield, QC, Canada
I appreciate the compliment, thanks, but I have no cabinet making skills at all. Only the very basic stuff. Once I figured out the design, I went to the local hardware store to get my wood. Do not tell anybody but I handed the measurements to the employee who used a $$$$$ saw to cut the pieces I needed. The benefit was twofold. First, the cuts were straight. Second, the highspeed saw ensured that the edges of the pieces did not crack as it often happen with melamine. I used T and L shaped screwed hardware to assemble the thing. To hold the wire shelf, I used high capacity adhesive hooks. The kind that you can remove without damaging the gelcoat. I did not want to use screws and leave holes if I ever decide to restore the space to its original state or change the type of wood to marine grade.
