 Capri 25 Specific Forum
 Wobbly Spreaders
LT_Smash
Initially Posted - 05/02/2019 :  16:02:08  Show Profile
Hi All,
Proud part owner of 1980 Capri 25, Hull No. 68 here.
The boat is solid and in remarkable shape for its age. One thing that concerns me is that the spreaders can wobble. If you grab the uppers and give them a shake the outboard end of the spreader wobbles fore and aft a good 3-4 inches either way. Catalina direct says that's not meant to be and that no replacement spreaders or mounts are available.
Apparently there is a pin through the spreader base and spreader, and they can wear, allowing play. If I can't replace it, can I just JB-Weld the spreader into the base perpendicular to the mast? My only other idea is to drill out the hole slightly and fit a slightly larger pin (and JB-Weld the pin in to prevent it falling out). Any other ideas?
Thanks in advance,
LT_Smash
joearcht
Response Posted - 05/02/2019 :  17:39:57  Show Profile
Congrats Smash,
I had a similar problem on 433 when I acquired it.
I found that Rig-Rite - K-SP22 of roughly 32" in length will fit as a replacement. Barely noticeable if ANY difference. I paid $69.00 a piece for two of them plus shipping.
I bet they are still available, but don't know how much inflation may have kicked in.
http://www.rigrite.com
Check them out first and compare the replacement before you try to repair. I've been happy with mine for 12 years now.
Good Luck
Joe W Hiller Jr
1985 Capri 25
Hull #433
SailTowery
Response Posted - 05/07/2019 :  08:11:59  Show Profile  Visit SailTowery's Homepage
I wouldn't think JB Weld would hold up to the loads put on spreaders. I would buy new spreaders like Joe above. I ended up having a friend fabricate new spreader brackets for me. Lighter and much stiffer. He'd probably make more for the right price.
Ben
Little Wing
Hull #422
https://www.facebook.com/capri25littlewing/
LT_Smash
Response Posted - 05/09/2019 :  09:47:46  Show Profile
Thanks to both of you for your comments and ideas.
TCurran
Response Posted - 05/10/2019 :  04:29:54  Show Profile
Originally posted by SailTowery
If I could figure out how to post pics, I would post some of my custom spreader brackets. :)
Can you post them on FB? Thanks
Tom Curran
1981 Capri 25 Hull #101 "Dirty Debbie"
1988 Watkins 30
PAFB, FL
TCurran
Response Posted - 05/10/2019 :  04:40:41  Show Profile
Ben, look on the left hand side, click on "Members Area". You'll have to sign in again. Once in the member area there are instructions to help.
Tom Curran
1988 Watkins 30
PAFB, FL
LT_Smash
Response Posted - 03/19/2020 :  13:39:06  Show Profile
Hello again all,
We unstepped the mast yesterday in preparation for crane-out/bottom paint.
I know why my spreaders are so wobbly - there is about a 1/4" gap between the outside of the spreaders and the inside of the spreader base! Nothing but a bent cotter pin to retain the spreaders inside the bases.
Can someone post measurements and/or a picture of you factory spreaders? Trying to figure out if the bases or the spreaders themselves are wrong. Will post a pic of mine soon.
***Edit*** just spoke to Catalina tech support and they didn't seem to think any of that is a problem at all, not even how much sweep there is in the spreaders. They pointed out that spreaders do need play to allow for rake and mast bend adjustments.
Thank you!
LT_Smash
Edited by - LT_Smash on 03/19/2020 14:30:28
SailTowery
Response Posted - 03/19/2020 :  15:32:27  Show Profile  Visit SailTowery's Homepage
Page 12-13 for spreaders...
https://cdn4.sportngin.com/attachments/document/0153/7656/Capri25ArchDrawings.pdf#_ga=2.7521522.1781207467.1584657039-1434130390.1582660338
I used this to make my spreader brackets which I posted pics of above.
Ben
Little Wing
Hull #422
LT_Smash
Response Posted - 03/19/2020 :  20:17:16  Show Profile
Here's my spreader situation. The bases look like they match the drawing architectural drawing Ben provided.
https://ibb.co/QHhz777
https://ibb.co/wNZkrM6
https://ibb.co/cb7g7vm
Upon removal today there were some translucent fragments of brittle plastic - bushing remnants maybe?
Thanks for posting pics of those Ben, they look really nice. And thank you Joe for the link to replacement spreaders.
Edited by - LT_Smash on 03/19/2020 20:21:29
SailTowery
Response Posted - 03/20/2020 :  09:25:38  Show Profile  Visit SailTowery's Homepage
LT, I would think you could make your own "bushing" with epoxy somehow.
My original spreader brackets were actually male pieces that inserted into the spreader. There was a foam bushing inside the spreader.
Ben
Little Wing
Hull #422
LT_Smash
Response Posted - 04/08/2020 :  08:55:48  Show Profile
I think I made a decent fix.
The cotter pins have been replaced with 6 mm stainless pins. These are larger than the holes in the spreader bases as the holes in the spreaders had been worn oblong by the wobbling with a small and flexible pin, and 6mm allowed me to round them out again by enlarging the holes with a 1/4" bit.
There was still about a 1/8" gap between the spreaders and bases, so I ordered a 10x10x1/8" sheet of silicone off Amazon for $8 and wrapped a strip of it around the mast-end of each spreader. It is not a super tight fit so the spreaders can still move as required by mast rake and bend, but they are snug and secure now. About $20 and 45 minutes total.
Edited by - LT_Smash on 04/08/2020 08:58:41
SailTowery
Response Posted - 04/08/2020 :  15:12:10  Show Profile  Visit SailTowery's Homepage
Russ, I really think your pay to post pics policy needs to change. I'm not sure what is accomplished by it but it sure feels counterproductive to establishing goodwill among Capri 25 owners.
Ben
Little Wing
Hull #422
Russ.Johnson
Commodore
Response Posted - 04/08/2020 :  19:31:31  Show Profile
I think there is a misunderstanding.
Posting photos on the forum is free.
Here are the procedures posting in the Testing Forum.
http://www.catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=2623
Russ Johnson
2005 C250WB Hull 793
