 Running lines aft
wm36
Initially Posted - 04/25/2019 :  19:36:23  Show Profile
I have become interested in running at least some of my lines back to the cockpit, thinking of the main halyard and main reef (maybe double line reef - still undecided about that). I have two questions:
1) I have a 1995 C250. It does not have the plate at the mast step for attaching turning blocks like some other years have. What have others used as a turning block on this vintage of boat?
2) I hate the idea of drilling holes through the deck, but it must be done if I make this addition. What are suggestions for waterproofing these new holes? I have seen descriptions of elaborate processes of drilling and enlarging and epoxy filling, and others using butyl tape. Any guidance here?
West Marine had a sale on a triple clutch so I bought one of those last month, but I'm waiting on the rest of the parts until I do more research.
Wayne
Wayne & Lynn
Hillsboro OR
1995 C250 WB #151
Peregrine
Response Posted - 04/26/2019 :  06:18:37  Show Profile  Visit Peregrine's Homepage
This came up recently so you might search for the topic. I posted a description of my set up I have triple clutches on each side. Here are analogue photos of the starboard side.
The difference is on the port side I ave a deck mounted winch behind the clutches. On port I have main halyard, reefing line and topping lift.
On starboard I have main out haul and spin halyard.
I can reef from the cockpit all on the port side and do it under one minute.
Well worth the expense and drilling through the deck.
John Gisondi
Peregrine
#4762
wm36
Response Posted - 04/27/2019 :  21:53:56  Show Profile
Thanks! I also bought the spinlock triple clutch from WM. But I don't have the mast plate on my boat. I have tried searching the forum but I can't find what has been used as a turning block if there is no mast plate?
Wayne & Lynn
Hillsboro OR
1995 C250 WB #151
Peregrine
Response Posted - 04/28/2019 :  09:50:28  Show Profile  Visit Peregrine's Homepage
"I can't find what has been used as a turning block if there is no mast plate?"
It's not so much "what's been used as a turning block" but what the block attaches to.
Without a mast plate you are faced with attaching a bar to the deck or mast which means drilling holes.
My mast plate just sits under the mast.
Here is an mage of the Catalina Direct mast plate.
John Gisondi
Peregrine
#4762
Response Posted - 04/28/2019 :  11:53:17  Show Profile
Yup--many owners (including me) added that plate--it sits under the tabernacle (mast base plate) so requires the mast coming down. The variety of holes in the flat surface are to match up with the variety of bolt patterns used by Catalina over the years... Mine had to have two more drilled in it--not easy with the equipment I had.
Peregrine
Response Posted - 04/28/2019 :  16:17:36  Show Profile  Visit Peregrine's Homepage
Mine is a little different, as you can sorta see in the photo above, and the PO added it so I don't know who made it.
Mine sits loose IN the tabernacle or mast base. That's why the bent parts with holes for the blocks are forward and aft of the mast.
I'm sure the PO (previous owner(s)) used it so no holes were drilled or had to line up.
John Gisondi
Peregrine
#4762
wm36
Response Posted - 04/29/2019 :  19:42:41  Show Profile
The mast plate looks like the way to go, but does it work on the 1995 model? When I talked to Catalina Direct about something else, I asked about the mast plate and they said it doesn't work on the 95 because of the compression post. Again, being a newbie, I don't understand the differences between model years, etc. Do you guys agree with this? Can you suggest a part number for a mast plate that would work on my boat?
Wayne & Lynn
Hillsboro OR
1995 C250 WB #151
Response Posted - 04/30/2019 :  03:55:45  Show Profile
He probably said that because on the 250 the post is metal. On the 25 it's wood.
zeil
Response Posted - 05/05/2019 :  15:31:14  Show Profile
When asked Catalina Direct the same question the answer provided was that the compression post and the tabernacle are one and the same.
The only way, unless someone on the forum has a different way of doing things, is to drill and mount gear to the deck.
Henk & Johanna
Edited by - zeil on 05/05/2019 15:32:30
