 C250WB Halyard Organization
RPLieser
Initially Posted - 01/06/2019 :  16:16:07  Show Profile
I need to add blocks/clutches to my C250WB. Currently, I have only the mast-mounted pivoting blocks with cam locks for the main/jib, and a cam lock on the vang as well. I'd prefer to make these changes without adding a mast step halyard plate.
Q1: Does anyone have good pics for this improvement?
Q2: The toughest piece seems to be #1 below... thoughts?
1) I could see replacing the pivoting blocks/cam with halyard turning block on the mast or dropping down to the deck... something like:
https://www.catalinadirect.com/index.cfm/product/2245/halyard-lift-turning-block.cfm
2) Then running through a deck organizer like:
https://www.catalinadirect.com/index.cfm/product/1200/ball-bearing-deck-organizer-large-double.cfm
3) Then onto some type of clutch.
Pics would be very helpful!
Thanks, -Patrick #312
Edited by - RPLieser on 01/06/2019 16:18:12
