 Cat 25 1985 to load on trailer
johete
Initially Posted - 10/27/2018 :  17:37:05  Show Profile
Does anyone know the measurement of the fixed keel from the point of the bow or the water line to the aft of the keel, and the height of the bunks. Any drawings or diagram of below water line would be of help. Will be loading on trailer in water, I have not loaded a sailboat yet and need to know if I have the right trailer. Any help is great, thanks
Mark Maxwell
Response Posted - 10/27/2018 :  22:12:14  Show Profile
I’ll get you some pictures and measurements tomorrow. My boat is sitting on the trailer now.
Mark-
'Impulse...’
1978 C25 #533 SR/DIN/FIN ~_/)~
Bakersfield, CA.
blanik
Response Posted - 10/28/2018 :  10:52:43  Show Profile
Hope this can help
1984 C25 FK/SR #4593
Lake Champlain
Mark Maxwell
Response Posted - 10/28/2018 :  17:02:48  Show Profile
My trailer has three pads but the measurements on the above photo are close. Here is what mine came out too:
and pics here:
Waterline at bow to forward pad (center) 7’
Stern to pad 5’
Forward pad to center pad 63”
Center pad to aft pad 61”
Forward pad across to forward 55”
Aft pad across to aft pad 61”
Aft pad height 37”
Mid pad 35”
Bow pad 39”
Bow pad to water line (lower edge) 20”
Keel guide support 22” from keel base
Mark-
'Impulse...’
Bakersfield, CA.
Edited by - Mark Maxwell on 10/28/2018 17:04:13
johete
Response Posted - 10/28/2018 :  17:44:53  Show Profile
This helps alot, i belive i have the right trailer. Thanks very much
Response Posted - 10/28/2018 :  20:30:19  Show Profile
Did you measure from where the pipe mounts to the trailer for each support (IE: trailer cross beam to the top surface of the carpeting on the pads for the front supports, and top of the trailer side rail (C channel) to the top surface of the carpeting on the pads for the middle and rear supports)?
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Edited by - GaryB on 10/28/2018 20:37:19
Mark Maxwell
Response Posted - 10/30/2018 :  16:40:27  Show Profile
Yes. Those are from the bottom of the welded post (top of the trailer C channel) to the top of the pad where it contacts the boat.
Mark-
'Impulse...’
Bakersfield, CA.
Response Posted - 10/30/2018 :  16:59:53  Show Profile
Thank you!
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
johete
Response Posted - 10/31/2018 :  17:26:59  Show Profile
Thanks for the info. Mark your trailer looks like the one i have. Is it a trail-rite trailer? If so is your surge brake working okay, i haft to replace mine
Akenumber
Response Posted - 11/15/2018 :  17:51:26  Show Profile
That is a great drawing. I wish I had it setting up my trailer. All I could find was plans for a cradle, but it got me pretty close. An adjustable trailer is a must. I spent all day in the water making adjustments the first time.
Ken
San Diego
84 C25 SR/FK 4116
The KRAKEN
Mark Maxwell
Response Posted - 11/18/2018 :  22:39:55  Show Profile
Yes it is a Trail-rite trailer. I had to replace the break system several years ago (rusted solid) but it still works. Just enough to help with slowing down. I had it set too tight before and was actually locking the front wheels...they are the only ones with the brakes. Once the surge was released the brakes also released so they are not as effective as say continuously applied electric brakes. The best thing for me was installing the load sharing receiver. That was huge in helping control the push effect coming down a steep grade. That and the truck I used to haul it was a Ford F-350 duelly. #128077;#127996;
Mark-
'Impulse...’
Bakersfield, CA.
