Great until you try to sail it when other boats are around. But as I recall, my cabin was "enclosed" too, and didn't look like that.
It makes living aboard more comfortable, but underway you can't see around it or over it unless you stand up. A real pilothouse boat has an inside steering station, and you can see through the front window. Visibility is very obstructed when steering from the cockpit.
Looks like a precarious perch, with no backrest, no handholds, no apparent way to steer from there. I wonder if it has a non-skid surface, in case the boat heels suddenly.
I just noticed, there appears to be a black electrical wire coming out of the starboard end of the white thing. The wire appears to be routed down one of the pushpit legs. Could it be a long, skinny solar panel, or perhaps a mount for a solar panel, with the panels removed?
It appears they’ve installed a window type AC in the forward section of the cabin house. Must be very comfy. I wonder if the owner installed remote steering and a forward-looking camera?
Good questions. The previous owner replaced the factory pop-up top, which was failing, with that structure which makes the cabin much roomier, height-wise. But it is a view-forward blocker. So the white thing on the stern is an upholstered bench to sit on so you can see over that cabin. I also steer standing up quite a bit, which also works. It is odd but seems to work fine. We haven’t sailed it since we bought it about a year ago, but the sails were in ok shape at that time. We just putt around with the motor, which is a really nice motor.
