 Can I stack these cheek blocks?
vdotmatrix
Initially Posted - 08/26/2018 :  15:58:00  Show Profile
I have a single on deck now, can I take apart these and combine them to make a triple?
https://www.westmarine.com/buy/schaefer--double-block-with-flat-base-4-2oz--10616399?recordNum=47
Edited by - vdotmatrix on 08/26/2018 15:58:56
Russ.Johnson
Commodore
Response Posted - 08/26/2018 :  19:39:54  Show Profile
The original supplier is Garhauer Marine.
They have a deck organizer which might even use the existing holes.
Garhauer home page
https://garhauermarine.com/index.cfm
Deck Organizer Selection
https://garhauermarine.com/catalog_process.cfm?cid=33
Deck Organizer with center bolts
https://garhauermarine.com/ProductSpecs.cfm?pid=446
Russ Johnson
2005 C250WB Hull 793
Edited by - Russ.Johnson on 08/26/2018 19:41:12
vdotmatrix
Response Posted - 08/27/2018 :  06:44:20  Show Profile
Sweet. We have these on the other c250...BIG THANKS
kjk
Response Posted - 08/27/2018 :  17:33:27  Show Profile
I stacked them and now have them three high.
Kevin J. Kiely
Rockport, MA
1999WK
Hull # 407
Russ.Johnson
Commodore
Response Posted - 08/27/2018 :  20:00:01  Show Profile
I reviewed the Garhauer links above.
There are several deck organizers and it's not clear which one might work.
Here's the detail
Model 30-DO-QB
Length 5-1/4"
Width 2"
Sheave Diameter 2"
I don't have this one, so measure carefully.
Russ Johnson
