 C 25 Very short wires to new deck connector
Sailingoldsailor
Initially Posted - 07/18/2018 :  09:03:45  Show Profile
I am replacing the deck connector on my 1984 C 25 and found VERY short wires in the access (1/4"-3/8").
Any clever ways to make the connection with the Catalina Direct 4 pin chrome brass fitting? It uses TINY philip head screws that lock in the bottom plate. Have managed to only lock in one of the boat wires at a time. VERY frustrating!
I am considering soldering a short pig tail to existing deck wires, then attaching to fitting. Not enough room for crimp connectors. Plan to bend into a small circle then cover with heat shrink tubing and push below 1/2" opening in fiberglass deck.
PLEASE HELP any better ideas? Have you ever done this? What are the pit falls other than totally rewiring?
Response Posted - 07/18/2018 :  10:44:22  Show Profile
That works, I did the same thing
Dave B. aboard Pearl
1982 TR/SK/Trad. #3399
Lake Erie/Florida Panhandle
Response Posted - 07/18/2018 :  19:41:27  Show Profile  Visit Leon Sisson's Homepage
I agree with the solder on a short extension approach. I've done similar repairs to the one cabin light circuit I haven't yet replaced in my C25. I totally rewired my mast lights, from masthead, to deck connector, to circuit breakers and switches, to batteries on both my C25 & C22.
Way back when I did the C25, I installed some huge gauge wire, like #14 I think, because I was installing incandescent bulbs. When I rewired my C22 this year, I used lighter wire, knowing it would have only LED lights.
I still haven't done a very good job of hiding the mast wiring in the head compartment of the C25. For the C22, I found some aluminum channel with snap-in plastic cover which did a rather clean job of securing the overhead runs of wiring in the cabin, if I do say so myself.
— Leon Sisson
WesAllen
Response Posted - 07/19/2018 :  07:57:24  Show Profile
I also extended the wire. Good thing because I have since replaced the connector a second time.
Wesley Allen
"Breaking Wind"
1982 C-25 SR/TR/SK #2773
Hemlock, MI
Edited by - WesAllen on 07/19/2018 08:00:34
Response Posted - 07/19/2018 :  15:08:42  Show Profile  Visit Leon Sisson's Homepage
Re: "I have since replaced the connector a second time."
I haven't been impressed with the thru-deck electrical connector originally used on the Catalina 25 (and 22). I replaced mine with the 5-wire Aqua Signal Watertight Cable Outlet and Plug Assembly, part #80100-7. About my only caution regarding the Aqua Signal connector assembly is to minimize the chances of a flailing jib sheet or other line to get snagged under the horizontal part.
— Leon Sisson
