 # of adjustments
Phredde
Initially Posted - 06/11/2018 :  11:06:50  Show Profile
Has anyone ever counted this? I want to use a sailboat analogy in a speech on something else, as in...even a basic sailboat has over __ things you can adjust to optimize performance.
I guess it depends on how you count some of these. But if we stick to non-spin, which I do, I get about 16, but am probably missing some...and who knows, I might learn something too...
Sail choice
Bottom scrub
Tiller
Heading
Main sheet
Jib sheet
Weight placement
Traveler
Backstay tension
Shroud tension
Cunningham
Outhaul
Reef
Vang
Halyard tension
Jib car
Phredde
Catalina 25
San Francisco
Response Posted - 06/11/2018 :  12:08:16  Show Profile
You can add leech line, foot line, downhaul, and sometimes a topping lift is used to help shape the mainsail in very light air.
Response Posted - 06/12/2018 :  03:33:37  Show Profile  Visit OLarryR's Homepage
Heel angle
Larry
Response Posted - 06/18/2018 :  09:51:00  Show Profile
How about 'attitude'? As in...how much do I care and how much do I want to work today/this afternoon? Some days you want every 1/4 knot of speed you can get...and other days, maximum efficiency matters less...
Jerry
Edited by - jerlim on 06/18/2018 09:53:37
Response Posted - 06/19/2018 :  11:35:27  Show Profile
"Barber hauler" for pulling the jib clew inboard for better pointing, and "twing" for pulling the jib clew downward to reduce twisting off toward the top.
