 Part identification please
Sublime
Initially Posted - 06/01/2018 :  14:19:47  Show Profile
I have only had this boat with the mast down. What is this and where does it go? Looks like it goes in the track in the mast maybe?
Link if pic isn’t showing https://ibb.co/g8LJqy
***This post is made of recycled electrons
Edited by - Sublime on 06/01/2018 14:20:50
Bladeswell
Response Posted - 06/01/2018 :  14:51:51  Show Profile  Visit Bladeswell's Homepage
Hi Sublime,
I would venture to say that it looks like a sliding goose neck. It attaches to the forward boom end and then the sail slot of the mast track. You will want at least one sail stop and maybe two.
Best of luck.
Bladeswell
Response Posted - 06/01/2018 :  16:22:59  Show Profile
Yep, Looks like the slide portion of the gooseneck assembly.https://www.catalinadirect.com/index.cfm/product/934_149/gooseneck-complete-with-slide-c-25.cfm
Sublime
Response Posted - 06/01/2018 :  22:43:32  Show Profile
Thanks all.
I wonder where the rest of it is, then. I'll check the boom I guess. Would this setup be for a cunningham?
Edited by - Sublime on 06/01/2018 22:47:50
Bladeswell
Response Posted - 06/02/2018 :  07:02:07  Show Profile  Visit Bladeswell's Homepage
Hi Again,
Yes, The line attached would go down to a cunningham. Though that line looks like it might be just a little short. Most likely, the other end of your goose neck is still attached to the booms forward end. If not, you can get a replacement from CD. (Catalina Direct).
Bladeswell
Lee Panza
Response Posted - 06/02/2018 :  14:46:38  Show Profile  Visit Lee Panza's Homepage
Originally posted by Sublime
Thanks all.
You might find a fitting permanently fastened to your mast for the boom to attach to at a fixed height instead of being able to slide up and down. This part that you've shown would then be superfluous.
With a fixed gooseneck you would need an actual cunningham, which is a cringle above the tack for a line to haul down on the luff and tension it. It's much more effective than just tensioning the halyard.
With a sliding gooseneck you raise the sail to full-hoist and then use the boom down-haul to tension the luff. This way, gravity is working with you instead of using the halyard alone. I installed a multi-part tackle to do this, but I don't really use it anymore (it seemed to help with the weary old mainsail that came with the boat). The short piece of rope attached to the slide in the picture could be tied-off to a cleat on the deck or on the mast.
Note: with a sliding gooseneck you should have something to hold the boom down.
Lee Panza
SR/SK #2134
San Francisco Bay
(Brisbane, CA)
Response Posted - 06/03/2018 :  12:21:29  Show Profile
As in this case, it's often helpful to us to know a little about the boat--for example the year. Until the late 80s, C-25s were made with sliding goosenecks, and this is the "sliding" part of that. The line is the downhaul, which is attached with a stopper knot to the bottom of the slider and can be tied off to a cleat you probably have low in the mast slot. The pin that holds the boom casting to the "clip" on the slider (or is that a bolt?) looks a little long--it should be a clevis pin just long enough for for the clip (with a cotter pin or ring). A longer clevis pin or bolt holds the sail tack at the top of the boom casting.
Edited by - Stinkpotter on 06/03/2018 12:24:24
