 making mast ladder
dasreboot
Initially Posted - 11/30/2017 :  08:03:35  Show Profile  Visit dasreboot's Homepage
watching this youtube video, and halfway through realized it is a cat 25. I think I'll point her to the association. she needs a little help with some things.
https://www.youtube.com/watch?v=06El7_01OW0
Todd Lewis
Eowyn 87 TR/WK C25 #5656
ARWEN 84 TR/SK C25 #4031
www.mainsailsailingschool.com
Response Posted - 11/30/2017 :  11:59:10  Show Profile
Oooooo... That forestay needs a new forestay! And the halyard probably needs to go down to a restraining block on the mast just above the level of the furler swivel so she doesn't get another halyard-wrap, which may have caused the damage to the forestay in the first place. But she's resourceful!
Response Posted - 11/30/2017 :  21:51:22  Show Profile
Hey, another Andiamo in the background at 7:25!
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
dasreboot
Response Posted - 04/25/2018 :  04:35:27  Show Profile  Visit dasreboot's Homepage
Made a mast ladder! I sewed it up like the commercial one instead of tying knots. Gonna try it out this friday when i can get someone to come with me tail a safety line. Either the windstorm we had 2 weeks ago, or an errant bird knocked off my windvane. Going to replace it.
Todd Lewis
Enchantment II
Response Posted - 04/25/2018 :  09:05:15  Show Profile
Hey Todd, I like your idea. Do you have details and measurements? What kind of material did you use?
Joseph Henderson
82-CAT 25 TR SK
kwalsh
Response Posted - 04/25/2018 :  09:14:37  Show Profile
Hi Todd,
This is on my list of To-Do's also. Is your's an SR or TR? Looking forward to learn it works out for you.
Many thanks!
Kevin Walsh
C-25, TR/SK
Kevin Walsh
Segelboot
1984 C25, TR/SK
Sail No. 4433
dasreboot
Response Posted - 04/25/2018 :  09:20:46  Show Profile  Visit dasreboot's Homepage
i have some pics i took, and measurements. I made it longer, in case i have a bigger boat in the future. I'll write up a howto after i try it out this weekend. I used 10000 pound polyester webbing from strapworks.com its stiffer than the lighter grades, which i hope will be easier to climb.
Todd Lewis
Edited by - dasreboot on 04/25/2018 09:23:11
Bladeswell
Response Posted - 04/25/2018 :  10:41:19  Show Profile  Visit Bladeswell's Homepage
Hi Todd,
Great job. Looking forward to your "How Too" update. I hope you will be including a materials required list as well. Thanks, can't wait to build one for my boat.
Bladeswell
Response Posted - 04/25/2018 :  14:04:53  Show Profile
A boatyard buddy bought a mast climber rig like that and he was using it the other day. He’s got a 32 foot boat with a 40 ft keel stepped mast so that was his only choice unless he hired a crane.
He took a belt and suspenders approach however. He also has a boatswains chair and used that with a friend handling the winch at the same time he climbed the mast. He also has a safety belt.
It was a little windy that day so I worried about the whole boat tipping off the poppets (aka jack stands).
In my case I decided to drop my mast to replace my windvane and check out my mast lighting. It was a little touch and go wrangling the rigging in the cockpit, but all’s well that ends well. Personally, I prefer working at ground level.
BKPC25
Response Posted - 04/25/2018 :  14:12:04  Show Profile
Here is a video of the same thing.
1" webbing with overhand knots.
Watch "Ep 5 Solo Mast Climb Catalina 25" on YouTube
https://youtu.be/VnEHUXawS7E
1973 C22 #1803 "Baby Adalynne"
(1979 C25 #1389 "Adalynne")
Instagram: #sailingadalynne
https://m.youtube.com/channel/UCQCd-egRgoAJi6fUvgEvI_A
Lake Travis, Austin, TX
dasreboot
Response Posted - 04/25/2018 :  17:47:26  Show Profile  Visit dasreboot's Homepage
I'll tell you after friday, but I think it will be much easier with the sliders attached to the ladder.
Todd Lewis
Peregrine
Response Posted - 04/26/2018 :  16:15:08  Show Profile  Visit Peregrine's Homepage
I didn't make my mast ladder I bought a "Cap't Al's" mast ladder. About $100, or 1 boat unit.
The nice thing is, it has PVC pieces on each step. That makes stepping up easy, secure and no looking down to find the step.
I would just caution anyone making their own mast ladder to really study the knots and take each and every knot seriously. 29 feet doesn't sound very high until you get up there.
I rock climbed before getting into sailing and each knot makes a difference.
John Gisondi
Peregrine
#4762
dasreboot
Response Posted - 04/30/2018 :  04:19:43  Show Profile  Visit dasreboot's Homepage
Well, the ladder came out great and my daughter claimed up three rungs. My short little legs couldn't make it to the next rung. Cursed with short legs and a long torso. Going to have to rip most of it apart and decrease the lengthy between rungs. That'll be a few weeks until I have time.
Todd Lewis
myersge1
Response Posted - 07/09/2018 :  16:18:31  Show Profile
I build a mast ladder out of 1" webbing with mast sliders. Works great other than it pinches my feet against the mast that gets pretty sore after a few minutes. I think I'll add PVC to each step as Peregrine mentioned to take care of that.
One thing about safety. Whenever I use it, I wear a climbing harness that is attached to the jib halyard with a climbing ascender. I attached the jib halyard to the base of the mast and make it tight with the mast wench. Each step up the ladder, I slide the ascender up as well. If the ladder does break, I'll only fall a foot at most.
Peregrine
Response Posted - 07/09/2018 :  17:09:48  Show Profile  Visit Peregrine's Homepage
I didn't make my mast ladder. I have a Cap'tain Al's. It is sewn webbing AND it has PVC pieces on each step. This holds the steps out to easily get your feet in and is a much more stable step.
John Gisondi
Peregrine
#4762
Captmorgan
Response Posted - 07/09/2018 :  19:24:04  Show Profile
I dont know after building and using the aframe to lower the mast I thingk its easier to lower it. Take your time and much lower risk. But I guess if your out there and have to fix a light or something its handy. Maybe we need both.
"The Gal-Way" 1985 SR/SK Barnegat Bay, NJ
Enjoy Sailing =) Be Safe
Happy Sailing - John
Photo Album
