 Check Your Sheaves
sethp001
Mainsheet C-25 Tech Editor
Initially Posted - 08/22/2017 :  16:51:52  Show Profile
If you have any resistance raising sails while in a lee or while pointed into the wind, check your sheaves at the masthead! Barnacle Bill Holcomb wrote a nice blog post on the subject a few years ago: http://barnaclebillholcomb.blogspot.com/2013/07/old-halyard-sheaves.html
In my case, I was missing the main halyard sheave completely, which I expected after finding sheave looking debris on the deck. The foresail sheave was badly deteriorated, which I should have expected more, but it still worked well! (See photos below.)
Main Halyard Sheave Missing
Foresail Halyard Sheave Deteriorated
One of Two New Sheaves Installed
Seth
"Nomad" 1980 Prindle 16
Edited by - sethp001 on 08/23/2017 17:33:50
Response Posted - 08/22/2017 :  17:52:18  Show Profile
We have discussed this a few times about those white ones deteriorating from the UV rays. Even CD mentions that when you look for replacements. Mine we're in the same condition although not totally gone.
Response Posted - 08/22/2017 :  18:19:45  Show Profile
A good reminder that shelves, like running rigging, need to be inspected and periodically replaced. All to often "out of sight, out of mind" results in problems when least convenient.
Peter Bigelow
C-25 TR/FK #2092 Limerick
Rowayton, Ct
Response Posted - 08/22/2017 :  20:59:20  Show Profile
(Peter's auto-spelling-corrector hadn't heard of "sheaves"...)
DavidBuoy
Response Posted - 08/23/2017 :  04:36:51  Show Profile
Wait, I thought you were getting new halyards?
Captain Rob & Admiral Alyson
mgarner
Response Posted - 08/23/2017 :  08:55:45  Show Profile
I will be taking a look at mine this weekend.
Marty Garner
"Midwatch" 1985 C25 4869 TR/FK
Response Posted - 08/23/2017 :  11:46:30  Show Profile
An early and important lesson for me was to change out the sheaves and get new tech halyards, it was my first experience with CatalinaDirect. Remember bushings are better than bearings for halyard tensions.
sethp001
Response Posted - 08/23/2017 :  16:55:40  Show Profile
Yes, I did. I replaced the sheaves before replacing the halyards. I guess I could take some photos of the sheaves and blocks with the 5/16" line installed.
Seth
sethp001
Response Posted - 08/23/2017 :  17:33:21  Show Profile
Yeah, I went with the sheaves without bearings.
Seth
hewebb
Response Posted - 08/24/2017 :  06:42:43  Show Profile
OOPS
My main halyard has a sheave with ball bearings which I installed about three years ago. The other ones are bushings. I had the mast down a few month ago to untangle the topping lift line that was twisted around the main halyard. Did not check for bearing damage then. Seems to work OK-so far.
Hobie 18 Lake Worth
Response Posted - 08/24/2017 :  08:27:17  Show Profile
I saw that the ball-bearing mast-head sheaves from CD have large-diameter bearing races, which they say spreads the load from halyard tension--apparently that's the circle on the side of the sheave. However, I witnessed the "explosion" of a Harken ball-bearing swivel block that turned a halyard from the mast out to a deck organizer--little red beads went flying all over the boat!
Akenumber
Response Posted - 08/26/2017 :  11:39:30  Show Profile
Changing the subject a little. How many of you have had to replace your masthead all together? Mine had some excessive corosion that caused one of the ears to crack. I used lots of mare lube on the new one.
Ken
San Diego
84 C25 SR/FK 4116
The KRAKEN
sailorbaz
Australia
Response Posted - 08/27/2017 :  23:18:47  Show Profile
Mine were aluminium and quite badly corroded. I got a local machine shop to turn me up a set in Delrin a couple of years ago and they are still looking good.
Sailorbaz
Sailorbaz
1981 Boomaroo 25, (C25) SK/SR, inboard diesel, Red Robin
South coast, New South Wales, Australia
Response Posted - 09/15/2017 :  19:47:50  Show Profile
When I got Limerick in 07 Replaced the masthead and the sheaves. I inspect both each season and am ready to replace the sheaves as it has been enough years that simple prevention is in order (and cheap insurance)
Peter Bigelow
Rowayton, Ct
