 Another thru haul ?
C25BC
Initially Posted - 07/22/2017 :  21:27:17  Show Profile
I have a 2 " threaded pipe under the port setee with a galvanized cap threaded on about 12" from the galley ,is this a standard feature ? Or if not why is it there ?
Angus
S.V.Tempus
#4748
1984 Catalina 25 SK/SR/Trad.
hewebb
Response Posted - 07/23/2017 :  04:56:44  Show Profile
If I had to guess. It may be where the holding tank could dump into the lake at one time. That is where my holding tank is located. If it had a Y valve that is probably where it would be. The pipe is probably a brass or bronze fitting and you may want to check the condition of the galvanized cap. I,m guessing it may rust out from the threaded area which may not be galvanized.
Hobie 18 Lake Worth
Response Posted - 07/23/2017 :  06:49:59  Show Profile
If the thru hull is forward of the galley sink drain thru hull and is under the aft section of the settee I would say that a PO installed it for some unknown reason. Catalina drawings of the plumbing thru hull's don't show any thru hulls in that location. A word of caution, If the pipe nipple or thru hull is bronze and the cap or pipe nipple is Galvanized steel, That is dissimilar metals and is a no no. The metals should all be the same. The entire assembly needs to be the same. All bronze or all plastic. ABYC P-06 standard / UL 1121 standards specifically states that all metals must be galvanically compatible.
Response Posted - 07/23/2017 :  07:38:13  Show Profile
Originally posted by islander
If the thru hull is forward of the galley sink drain thru hull and is under the aft section of the settee I would say that a PO installed it for some unknown reason. Catalina drawings of the plumbing thru hull's don't show any thru hulls in that location. A word of caution, If the pipe nipple or thru hull is bronze and the cap or pipe nipple is Galvanized steel, That is dissimilar metals and is a no no. The metals should all be the same. The entire assembly needs to be the same. All bronze or all plastic. ABYC P-06 standard / UL 1121 standards specifically states that all metals must be galvanically compatible.The only reason for it's location that I can think of is that your boat has or had a marine head and the PO wanted to discharge overboard.
