I believe that, on an outboard powered boat, the ground is usually just connected to the negative battery terminal. That's the way I did it on my C25, and it worked well. When you think about it, a handheld vhf radio isn't grounded to a bronze through hull, and it works.
Maybe the ground connection is dirty or corroded or just loose.
I've been led to understand that VHF radios don't require actual grounding as do SSB and some others, and I've never grounded mine. (The negative side of the battery in a DC system is often referred to as "ground", it's really just the other side of the circuit--not like the ground in an AC system.
In my experience, the most common cause of poor transmission and reception is corrosion and/or gunk in the antenna connection at the radio. Put some alcohol on a fine-textured Scotchbrite pad and rub it on the threads on the radio and in the cable connector, being careful not to bend the wire in the middle of the connector. See if that helps.
If it's not a portable radio it should be grounded to the ground bus bar or terminal behind your switch panel. The positive should be connected to a fused switch or a POS. Lead. The antenna is grounded to radio through the coax cable..Dave is right that what is called a ground is just the neg. Side of the circuit
Most boats are made of fiberglass and don't have a through hull grounding plate. Typical size would be 12"x12" or larger. Most boats' VHF radios work pretty well, however, I hear spark plug interference and alternator whine often enough from other boats. I'd say that the most important issues are (1) corrosion on the threads of the connectors, (2) bad crimp between the connector body and the cable shield (ground) wire, (3) intermittent or corroded center conductor between the connector and the receptacle, (4) electrical interference (engine & alternator). With on average 3 or more connectors between the radio (1) and the antenna (2), add a barrel at the mast and that's 4. That's where I'd look first. Fwiw, you could connect 20ft of #16 wire to the radio's ground lead, connect a large sheet of tin foil to the other and toss it overboard. If your radio works better then you'd know.
Reading through the responses it appears we have a communication/ terminology issue. A fixed VHF of course has a pos. and neg. lead in addition to the antenna. Most, in addition, have a separate screw that is recommended to be attached to "ground". I believe it is this connection that is in question. Descriptions of how to wire this are typically vague although as already noted, I believe can be optionally connected to the negative side of your DC system.
...Most boats' VHF radios work pretty well, however, I hear spark plug interference and alternator whine often enough from other boats...
...perhaps because they grounded their radios to a bonding system or the inboard engine and thereby to the water. West Marine, in discussing grounding systems (AC, DC, RF, and lightning protection) says this regarding radios:
quote:Your VHF doesn't need to use the ocean as a counterpoise, so here we are dealing only with the ground needed for your HF/SSB radio...
