 New town vehicle
Bladeswell
Initially Posted - 05/17/2016 :  06:39:52  Show Profile  Visit Bladeswell's Homepage
Hello Everyone,
Just bought a new used tow vehicle for the boat. I hope it will work out well. I bought a 2001 Ford Excursion limited edition. Its a 3/4 ton. Built on the Ford F250 chassis I'm told. A V-10. Should have plenty of power. What do you think. Thanks.
Bladeswell
Response Posted - 05/17/2016 :  10:58:46  Show Profile
Very good choice - that is other than it being a Ford
1989 C25 TR/WK, #5822
1973 McVay Minuet 19
1975 Jester 12
1981 C25 SR/SK, #2428
1981 C22 SR/SK,
Tanzer 16
Sunfish
offshoreaccount
Response Posted - 05/17/2016 :  13:35:11  Show Profile
might be a bit underpowered. best to avoid the hills.
Offshore Account, 1977 Hull #243. SR, SK
sethp001
Mainsheet C-25 Tech Editor
Response Posted - 05/17/2016 :  13:58:12  Show Profile
That will make for a great tow vehicle. Yes, same as F250, plenty of power, great chassis, great transmission. How many miles old are the spark plugs?
Seth
"Nomad" 1980 Prindle 16
Edited by - sethp001 on 05/17/2016 13:59:29
Bladeswell
Response Posted - 05/17/2016 :  14:13:08  Show Profile  Visit Bladeswell's Homepage
Hello All,
Yeah, I've never been a Ford man but hey its what I found and
bought. Might be under powered, a v-10 ? I really hope that was a joke.
I don't know how long ago it had it's last tune up but it isn't missing just now. But here I was all jazzed that it had plenty of rubber left on the tires when on the drive back to my truck yard one of them decided to throw off it's tread. Bummer, had to spend $200 for a new one this morning. Well better now than while towing the boat. Thanks Guys.
Bladeswell
offshoreaccount
Response Posted - 05/17/2016 :  14:37:51  Show Profile
It was a joke. looks like capacity is 11000 lbs. more than enough.
sethp001
Response Posted - 05/17/2016 :  15:14:19  Show Profile
Originally posted by Bladeswell
Hello All,
Bladeswell
In your year Excursion, the length of the threads on the spark plugs is approximately half of typical plug thread length and the aluminum heads casting may be softer than typical. So the threads in the head can be stripped easier than on other engines. Being aware of the issue, some mechanics under-torque the plugs, which then wiggle loose and blow out.
If you do your own mechanic work, be careful to torque the spark plugs to the proper spec. There are several incorrect torque specs floating around on the Internet. If you have a shop do the work, make sure its a good one familiar with the issue or maybe go to a dealer.
I hope this doesn't sound too negative. If you run into spark plug issues later, there's a great retrofit that's relatively inexpensive. The Excursion is a great truck.
Seth
Edited by - sethp001 on 05/17/2016 15:19:22
Bladeswell
Response Posted - 05/17/2016 :  16:42:43  Show Profile  Visit Bladeswell's Homepage
Hi Again,
So glad that was a joke. And thanks for the info regarding the plugs. I was not aware yet that my heads were aluminum. Hopefully the years have made progress with them. I remember that the early aluminum heads and blocks were really troublesome. Thanks again.
Bladeswell
Response Posted - 05/17/2016 :  17:56:12  Show Profile
Written humor can be tricky... For tongue-in-cheek respnses, we have some built-in hints...
, , , , , , , etc.
offshoreaccount
Response Posted - 05/17/2016 :  19:38:47  Show Profile
Yes, but then it doesn't seem as dry if you include the hint. Part of the joy is the other person sweating for a moment.
Having said all that, I am in the market for a second vehicle in the next year or so for towing, and the excursion is one I hadn't considered. I had an '04 durango in the past, but buying one for a tow vehicle seems foolish given how god damned unreliable the thing proved to be. I loved that car so much, but anything that could go wrong did.
Edited by - offshoreaccount on 05/17/2016 19:40:04
Bladeswell
Response Posted - 05/17/2016 :  22:07:34  Show Profile  Visit Bladeswell's Homepage
Hi Again,
And for a moment I did. Mission accomplished...lol.
Bladeswell
Response Posted - 05/18/2016 :  06:47:41  Show Profile
1975 Jester 12
1981 C22 SR/SK,
Tanzer 16
Sunfish
Akenumber
Response Posted - 05/19/2016 :  17:38:44  Show Profile
Do pay attention to the sparkplugs. If you wait until the factory service interval, it's too late. Better replace them now and with antiseize before they try to come threw the hood.
Ken
San Diego
84 C25 SR/FK 4116
The KRAKEN
MrKawfey
Response Posted - 05/19/2016 :  18:02:10  Show Profile
I had a 97 Dakota with the 5.2 and 3.92 gears and it towed the boat great. I sold it and a few years later decided to get another one because it had the highest tow rating of any compact/midsize truck. I ended up buying an 06 and it turned out to be the most failure prone vehicle I have ever owned. It also struggled to tow the boat despite having a higher rating than the 97. I loved the truck and kept it for seven years but after the latest high dollar repair this winter I decided to cut my losses and let it go. I bought a '15 tundra and couldn't be happier.
There is a great website, trailer life magazine, that has detailed guides with tow ratings for every vehicle in every configuration available for that year. It's worth noting that tow ratings are pretty subjective and the manufacturers can set them just about anywhere. There is a new standard rating system but only a few companies certify to it.
Chris
Sacandaga Lake, NY
1984 C25 SRSK
"Les's Moor"
Edited by - MrKawfey on 05/19/2016 18:02:57
offshoreaccount
Response Posted - 05/19/2016 :  18:04:59  Show Profile
Yeah, my family was a dodge family, and we had a dakota that was a few years older than the durango (purchased new). Same story with reliability. Needless to say, we haven't touched a chrysler product since, and I'm not too fond of fiats.
Edited by - offshoreaccount on 05/19/2016 18:05:14
Response Posted - 05/19/2016 :  18:43:32  Show Profile
Actually, most of the manufacturers are onboard with the SAE standard as of 2015. The advantages of the new trucks include amazing, for a truck, mpg. My F-150 gets 20 city, 22 overall, and 25 highway and the other brands have also improved significantly. Chrysler"s small diesel gets rave reviews for smoothness and excellent economy with really good tow capacity.
Dave B. aboard Pearl
1982 TR/SK/Trad. #3399
Lake Erie/Florida Panhandle
MrKawfey
Response Posted - 05/19/2016 :  18:48:46  Show Profile
Man, those mpg numbers are making me jealous. The only thing I don't like about the tundra is the 15 mpg I get on the highway
Chris
Sacandaga Lake, NY
1984 C25 SRSK
"Les's Moor"
Bladeswell
Response Posted - 05/19/2016 :  19:11:06  Show Profile  Visit Bladeswell's Homepage
Hi Again,
Wow, I am surprised to hear that the Tundra gets such poor mileage. I would have thought it would be better. I am not looking forward to seeing the mileage mine is going to deliver being a V-10. And I bet the fuel tank is at least 30 gallons. I haven't yet had to put gas in it.
Bladeswell
Response Posted - 05/19/2016 :  19:19:11  Show Profile
...and I'm not too fond of fiats.
Ahhh, the Fiat 850 Spider--our first and last disposable car (1969-new). Drive it for two years, and then throw it away. Every component has reached its useful life.
Response Posted - 05/20/2016 :  17:01:22  Show Profile
I just hope it isn't your daily driver and a 20 mile commute.
MrKawfey
Response Posted - 05/20/2016 :  17:14:06  Show Profile
No daily commute, I work from home. But we did intend for it to be the road trip vehicle
Chris
Sacandaga Lake, NY
1984 C25 SRSK
"Les's Moor"
Response Posted - 06/14/2016 :  20:03:37  Show Profile
Friend of mine had a F-350 Ford dually with the V-10 when they first came out. He got about 10 MPG pulling boats but he could pull a 28' cruiser at 80 MPH and not even feel it!
And yes, he was a little crazy!
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Edited by - GaryB on 06/14/2016 20:05:48
MattL
Response Posted - 06/24/2016 :  17:12:27  Show Profile
We got a 2015, 2500 dodge ram diesel. Have gotten about 21 on the highway, about 17 or 18 in town. Just pulled the boat on about 130 mile round trip getting about 15. Not a hitch on the drive.
Matt/Brigitte Loeffler
E.C. Rider 5411
Cat 25 86'
FK/SR _/)
