 outhaul wire
mdidomenico
Initially Posted - 03/26/2016 :  17:28:58  Show Profile
my outhaul line is currently the stock setup with a 2:1 purchase inside the boom, which has a 5/16" line running outside, with a short piece of 7x19 3/32" wire connect through the end of the boom to the sail.
does this short piece of wire need to be wire? Since i've got the boom in pieces i was thinking of upgrading to a higher purchase, but i'd like to alleviate the wire and maybe use a short piece of vectran.
the 7x19 wire looks like it's a little less then 3mm probably 3/32" wire which WM shows as 1760 breaking, 3mm V12 single braid vectran shows 1900 breaking. Even if my micrometer is a little off, i think we're still in the zone for breaking strength, is there any other reason this should be wire?
Response Posted - 03/26/2016 :  17:59:49  Show Profile
I'm a C25 guy, but isn't a few inches of the end of the outhaul exposed to sunlight, where it attaches to the clew? Vectran is degraded by UV. Stainless is not.
mdidomenico
Response Posted - 03/27/2016 :  05:26:28  Show Profile
Ah, yes, good point.
However, according to New England Ropes
"Very little degradation from sunlight. Can be used outside over long term if inspected regularly."
I might still go rope instead of wire, just because of my utter distaste for wire (been snagged/cut/poked too many times)...
Response Posted - 03/28/2016 :  20:48:04  Show Profile
I'm a little surprised by a wire out-haul on a C-25--never seen or thought about it. Mine was some nondescript double-braid rigged for 2:1 purchase. That and my newer Krypton halyards withstood plenty of UV--the core of double-braid is protected from it and takes the load.
Response Posted - 03/29/2016 :  04:42:46  Show Profile
Obviously I don't like being snagged by a wire, but I have always considered it a clear warning that the wire needed to be replaced. I've found that as soon as I replace the broken wire, I don't get snagged anymore. I'd rather get a little snag than have the wire fail suddenly and without warning under load.
