Okay, I know this is not the traditional way to mend a sail, but I have had outstanding results from this method on my kites for kiteboarding in the past, and so I called the company KiteFix and they informed me that they have a product for mending sails called SailFix. I'm trying it. It took about 2 minutes to install, should be good for the next several years. I'll let you know how that goes.
Here is the problem, a five cm rim in my jib sail:
And here is the fibreglass matrix + flexible bonding agent fix (SailFix) :
The advantage is that it's effortless to install, it's permanent, and it's over in 2 minutes. Let's hope for the best.
The company claims it's a permanent repair. Time will tell. Based on a google search, it looks a little expensive. $48. was the price I found for a small kit. The other way to repair the sail would be to sew a small piece of sailcloth over it. A home sewing machine could do it, if it's only through 2-3 layers of sailcloth. If it's more, then you'd either need a more powerful and expensive machine, or have it done professionally. If you don't have a sewing machine, I think the kit would be a good solution. If you have a sewing machine, and the machine is powerful enough, I think it would be cheaper to sew a patch over it. Each method has it's pros and cons.
